I had one in my F150 for 8 months, worked great. Never a problem.
Got the one for my AT4 for $79. Got it after the fix and it works flawlessly.
On 5/25/2019 at 1:33 PM, BBrutus said:
I’m sure they make good but I’m done.
So you just tossed $80 in the trash? I find this incredibly hard to believe. I love my auto start eliminator.
Not hard o believe, It’s not worth the efforts anymore possibly breaking my console. I’m going to go another route. Hopefully it will work for everyone! ?
I received notification of the Auto Stop Eliminator recall while I was on a 9 day trip.  Just like the notification stated, my battery was completely drained.  I appreciate the company being up front and I had a replacement part sitting on my door step by the time I returned from my trip.  I have no regrets about the purchase and the company made it right.
  • 3 weeks later...
5 hours ago, BBrutus said:
Anyone now have the replacement? Is there still a draw on power?
Thanks in advance
There is apparently no draw of power problem. i can click it on and off when i want to and it actually takes effect.
Got mine right after the recall. It's been in for about a month and no power problems.
Same here
On 5/25/2019 at 1:42 PM, BBrutus said:
Mine went straight into the garbage after all of this, no need to take it all apart if it has issues again replacing a second one. One and done.
Hopefully they have it right this time and what did they change? We really should have a thorough explanation of what happened and how they fixed it to insure this doesn’t create problems here on out. I mean we pay for a item, it doesn’t work and we are just supposed to think and trust this product.
A nice wiring  diagram proving it is no longer a potential problem in the future...the fix...?
I’m sorry, but in order to maintain our competitive advantage we can’t share the exact details of the changes. Please understand that in spite of extensive testing, undetected issues can exist. The problem with our device went undetected during testing because the test trucks were driven daily. Also, since the body control module is what was using the power, we didn’t see this when we checked the draw on our device.
It is rare that a manufacturer offers unsolicited replacements upon discovering an issue. We hope that the way we handled the situation demonstrates our level of commitment to our customers. If you would like to discuss further please contact us at [email protected].
  • Like 4
Are you positive the problem has been corrected? How long did you let a truck sit in order to test?
We are confident it is fixed. This was a very specific problem of the BCM not sleeping and drawing power. After 10 minutes the BCM either sleeps, or it does not. We compared baseline readings at the battery with and without the old device installed. The difference was visible. With the updated device, there is no difference. The device is no longer keeping the BCM from sleeping.
Letting test trucks sit for an extended period of time was unnecessary in this situation.
Mine is the updated version- everything works perfectly.  Not only did they send me a replacement, they also emailed me to make sure it was working properly and that I was happy.
Great customer service from a great company imo.
Shit happens.  They made it right, and quickly.
Edited by Limelight
Dang, I wasn't even in the market for one of these but the way you handled the whole issue makes me want to buy one just to support y'all.  How hard is the install.  Are there instructions?  I'll just YouTube it if needed or what not but was just curious as I'm not to keen on modifying my 1 month old truck yet.
Edited by Philipgonzales3
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
