Unsettling Experience
The ripples in the dirt were the perfect storm and it's probable I'll never experience that again. The front end stayed firmly on the ground while the back end jumped quite a few times and was a foot off. If people want to blame that on the driver, let them. They are being stupid on purpose. It was a straight road, mentioned that many times. I can keep repeating things here and people will still bring up things because they can't stand people disparaging their products. It's like watching a possum protect its trashcan.
  • Replies 131
So the story has changed from a what sounded like a little dirt over the road to a washboard like surface? A solid rear axle on leaf springs will move around a good amount on washboard roads regardless of how straight it is, especially if there is a crown on the road. There is no safety issue, under the exact same circumstances the other brands would have done the same, it is a characteristic of the solid rear axle.
The reason people are jumping down your throat and questioning you is how you came off at the beginning of the thread sounding like a complete troll...
"Should have stuck with a Ford, it never did that. That Chevy is a piece of shit, there, I said it". You also never drove the ford over the exact same situation...
Below shows the movements on a rough road even in a straight line...
Tyler
It was a little dirt, about an inch high, 8 foot long. That's never changed. My truck didn't even shudder that much as the video, you're so way off.
The front end never moved, it stayed planted while the back end swayed wildly. And, looking at the picture, it wasn't that bumpy, not even half.
Keep grabbing for straws to justify your biased stance.
You know... I'm seeing 2019 Sierra AT4 owners reporting the same thing.. like this.
https://www.silveradosierra.com/suspension/rear-has-excessive-bounce-t710283.html
So I'm not the only one and the responses there are much better. I've learned not to go for a forum full of fanboys who attack anything legitimate. Keep yourselves stupid.
3 hours ago, Wiggums said:
I looked into that the same day.. all show 36 to 37. That was one of the things I looked at first. On the Ford forum, one had gotten his tires up to 45 and mentioned he nearly went off the road.
I really cannot find anything wrong except that the back is empty. I initially looked into getting all four up to 40 psi, but that doesn't look likely. What psi do you keep yours at? I'm always looking for ways to get my gas mileage up without compromising the safety. Getting 28 mpg on my current V8 Silverado while all are 36 is pretty good, I was able to increase gas mileage on my 2016 F-150 by getting all four tires up to 41 psi.
I'm just getting used to it. Overall, it's nice and I haven't experienced the back end sliding again. The perfect storm might have caused it and I probably won't see that again. I did a little off-roading, it's actually more stable and ride was nicer than my previous F-150, but it could be due to the Z71 package.
I keep my fronts at 35 and rears at 33 cold. But my tires are wider by1” than the OEM tires and I don’t care ND MPG,  I do the chalk test to get the tread perfectly even across the ground.
I'd expect it to stay planted better. My front end really sticks to the ground, even better just about all pick-up trucks I've driven, but I just wish the rear end can do the same.
I'm thinking about getting tires down to 35 all around and will check into shocks. I am finding info on the best shocks in other forums so I'm all good. Thanks! :)
11 hours ago, the wanderer said:
Here's the thing; your story doesn't add up. The laws of physics are against you, since there is no way an inch of dry dirt, by itself, can possibly propel your truck in the manner you are claiming it did. Either the road was rougher than you remember, or you hit something you didn't notice was there, or you're exaggerating the effect.
Laws can be broken.  Even the laws of physics. *Gasp*
Please don't tell him that, he can't process that much information! It's too much, he'll only get confused. I keep repeating things and they don't get it!
10 hours ago, Wiggums said:
The others can speculate as much as they want [...]
lol but he ignores the reality that blaming his truck is pure speculation on his part.
11 hours ago, KARNUT said:
I think what most people are missing here is if he thought he was responsible he would probably say don’t do this because this will happen. If he was gassing to hard wouldn’t traction control intervene?
It's not about whether he thinks he is responsible, it's that he won't even consider the possibility that he *might* be.  That's a closed mind, not an open one that is trying to figure out what really happened.  That's why he won't be reasoned with and cannot be taken seriously.
On the traction control question I have to say I've been pretty surprised by it honestly.. it's way more permissive than I expected.  The BMW ASC/DSC systems are way more active and involved than this Silverado has been for me so far.  I've purposely caused mine to lose traction a few times and the light rarely comes on.  Still trying to get to know my truck and how it reacts.. gonna take a while longer and some more experimentation.
So let's say you did hit the guy and were in court for misdemeanor death by motor vehicle or whatever they call it in CA. Would this still be your defense? I think you'd be found guilty, my friend. Then in the civil suit I can easily see contributory negligence all day long. I guess you would try and sue GM even though, at least on this forum, you are the only person to ever experience this "perfect storm" of driving through "a little dirt." I would hardly call it a "safety issue" as it has been stated numerous time, no one here has ever experienced the close encounter with the third kind like you did on that fateful day. Maybe you should write a book about it...
21 hours ago, Wiggums said:
It's your prerogative to dismiss anything that insults your brand. You're clearly biased. Others offered solutions, you're accusing me of either lying or making it up.
I just said it as it is. The other truck I've driven was Ford which has never done that. I am not new to trucks but I can tell you this: I'm disappointed with the Silverado.
Suck it in, boy, you're a Chevy fanboy.
Yep
17 hours ago, Daverado said:
Sure, maybe it was the truck.  That's possible, albeit improbable given your inability to reproduce it.
Until you're willing to admit maybe you made a mistake though, no one is going to take you seriously.  Only when they take you seriously will people generally start to consider other possibilities, even just playing devil's advocate for fun.  That's just human nature.
As long as you keep insisting you couldn't possibly have made any mistake at all, you are showing that to be a serious flaw in your character.  It's a contradiction.
We can only hope......
  • txab locked this topic
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
