Vehicle hacked and being tracked...
New to forum. How's ya?
I was looking for some input on how someone can be tracking my vehicle. I've disconnected the shark fin. Is there some internal antenna involved, an account linked to my truck. I suspect they somehow obtained the software info from my vehicle because I know it's been broken into(no physical damage from entry), things stolen. The text alerts option on the display stays "on" sometimes without me being able to turn it off which I read somewhere that is a sign it's hacked(they get phone text about my driving info).Can someone crash course me on this. I know for a fact that it's going on. What can I do to solve this issue? Thanks.
Assuming you aren't a high-value target of a gov't (and you would likely know why you would be, if you are), I would first consider maybe your truck has an electrical/electronic problem, which results in things being reset to their default setting.
I think that is one of the few times I would take the vehicle to the dealer even if I was out of warranty.  I’d want them to reset everything and help you identify what’s going on if any issues return.  Not sure if this is possible, but maybe they can change your identifying information so you can get a fresh start.  Do vehicles have a MAC address?
I was a Federal Employee only an Act of Congress could fire and became a Environmental Protectionist ....a target of the .Gov/DoD for a bit.
Back it into a lake boat ramp claiming an accidental boat launch gone wrong.
Do not buy another vehicle with a computer in it.
2014 See eye Eh .DoD..went active taking over vehicles for targeted killings. Thats a fact jack.
You take that can to the Dealer and explain what you are seeing, they will fit you for a straight jacket.
BTW.....stealin aluminum wheels from Dealer vehicles went way down since Congress mandated those wheels transmitting serial numbers...ahem....I mean tire air pressure...after 2007.
There’s the first basic broadcasting.
I have your wheels transmitting their serial numbers I can track you around a city.
If you are serious ditch your cellphone and every computer you have. You could just have a pretty wife someone wants...and they have unlimited power to get her.
How is it possible to have a vehicle tracked without a connected sharkfin antenna, also info about the vehicle, speed, location, etc? Is there some internal antenna somewhere I'm not aware of? The remotelink app would need this antenna to communicate I'm assuming.
Strip it to the frame and see if someone installed a gps tracker without you knowing.
Common places are behind the radio, near the obd port, and inside the fuel tank.
Glad I replaced all of my TPMS sensors with cheap Chinese eBay knockoffs last go round.  Now the only serial numbers that I’m flinging about are encrypted with mandarin hieroglyphics and go straight to the Chinese government so they can better target my Amazon ads.
I’ve always wanted a sloth-themed seat back organizer with integrated ice cream freezer and toaster oven. Maybe now I can find a decent price on one!  The only ones I’ve found are >$300 and require 15.8-17.43 Vdc to operate and I just can’t swing either right now with this economy.
If I don't read anything else today, I'll be happy.  There's more goodness in those two sentences than I've seen in a very long time.  Kudos, sir.
If you want to spend some time reading, there are other threads talking about guys like you who want to remove onstar from the vehicles for various reasons. I think the onstar equipment is the only way for outsiders to gain access to your vehicle.
I don't know if you can really achieve what you want to do and still retain the rest of your electronic functions. But happy reading!
Thanks for the info. I've had the ONSTAR disabled for some time now. I once read an article about "text alerts" being "on" or "off" under the text icon on the display, obviously, but having trouble finding this article again. I remember it mentioned that it is a way to tell if the system is hacked, forced "on". I'm just assuming someone could receive vehicle info from it through an app or some other program. Mine seems to be forced "on" at times without me being able to turn it "off".  Any other time I can switch it on or off at will, normal operation. Just not sure how it's possible with antenna disconnected.
If if it's not able to broadcast, then perhaps it's just an electronic gremlin and not a hacker or someone else tracking you? Have you tried to push the onstar button after removing the antenna to see if they can respond or find you? does your in dash GPS still show your location? If so then there may be another antenna somewhere else?
With your remote, unlock your truck and leave it unlocked. Pop the hood and Unplug your battery terminal for approx 15 minutes. Reinstall and your vehicle will reset. My wife’s Escalade did that very same thing and turned out to be a bad ground battery cable.
Sent from above
Have you tried a USB version?
I was having power supply issues amd fuse coordination was tricky, I"ve had good luck with my toaster moving to USB power.
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,530 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
