1 hour ago, AJMBLAZER said:
Pretty sure people have reported the noise with SU5 front axles.
So far I've only heard of issues with the the SU4 axle which is made by American Axle Manufacturing. The SU5 axle is listed as GM Manufactured but I believe they sub that out to Delphi-Nexteer. What I'm not sure of is if the SU5 axle is only on the Trail Boss model which may be a longer axle like what GM provides with their 2" suspension lift or if certain powertrain packages require the SU5 axle.
Now that it is getting colder out the noise seems to have lessened. It's a real challenge to understand what would be different between the axle types as well as the influence of ambient temperature to cause the noise. So for now I wait while BBB processes my claim and call the dealership once a month to find out if the regional brand quality manager has gotten any updates from GM Engineering. Unfortunately there doesn't seem to be any other options as GM is definitely not in any hurry to fix it... 3 model years of vehicles and counting.
Happy to say this will be my last post. I ran auto four-wheel drive for about eight weeks after researching and finding that it wouldn't hurt my drive train.  I initially thought about running it that way permanently and from time to time I would switch back to two-wheel drive. I'm happy to report that I no longer have the jingle and I've been running two wheel drive for several months. I don't know if auto four-wheel drive was the reason or it just needed about 15,000 more miles, but this is my story.
Good to hear Philo!
I cannot say that mine has corrected itself as the noise seemed to lessen or even go away with the winter temps.  When it gets warm though (mid 40s and higher) the noise comes back.
At this point I'm going to do the GM Suspension Lift Kit as it replaces the front CV axles.  If the issue goes away completely then I know 100% it was the SU4 axle.
 One axle is made in Mexico and the other in the States.  There is no selection process for what vehicles they go in.   The Trail Boss axles are irrelevant to the differential they go into.
  • Thanks 1
Share your information sources.  Per GM regional brand quality the SU4 axle is made by American Axle and the SU5 is made by GM (most likely subbed out to the former Delphi plant now run by Nexteer). Country of origin isn't known and to be quite honest doesn't matter as same manufacturing processes are used around the world.
Haven't seen anyone share yet which axles go on the Trail Boss or if a Trail Boss has the same issue. It is relevant because the factory lift on the Trail Boss is same as GM factory lift that is sold as aftermarket accessory for non Trail Boss models. It comes with a different diameter cv axle to compensate for the increased angle at the differential.
I had the dealer install the lift with the new cv axles and so far the noise is gone. GM Engineering won't authorize repairs of replacing SU4 axles nor differentials as that doesn't fix the issue. But it seems a different axle part number (oe- different axle design) may fix the issue. So in that perspective it is relevant to know if the Trail Boss axle is yet a different part number with corresponding RPO code.
The noise doesn’t come from the CV shafts. It comes from the axle stub shafts inside the front axle.
Right, the axle shaft as a component of the inner CV joint of the front axle assembly.
All I know is that on my truck the noise comes from the driver's side axle assembly. With truck on the ground the passenger side inner CV joint is tight (almost no movement). However, the driver side inner CV joint has movement and makes definite metal on metal sound. Again the passenger side doesn't have this at all.  After the GM suspension lift with new front axle assemblies was installed the driver side is now tight without metal on metal contact noise.  So, seemingly corrected so far.
If I had to guess, I would say there is a tolerance stack up on certain axle assemblies married to certain front differentials that causes a poor fit. So the inner cv joint is "loose" and floats around in 2WD but is engaged in AWD so the noise goes away.
Does that sound plausible?
Maybe. However the GM fix and attempts weren’t about the cv shafts but the stub axles inside the diff. They replaced my driver’s side stub shaft and it fixed it. Still using original CV’s.
When you say stub shaft do you mean the outer ring axle (or roller housing) at the inner cv joint? The "short" or "stub" axle mating to the front differential in the attached image.
If so then that makes sense because that is the component that fit loosely on my truck. My dealer won't attempt a repair though because of the GM bulletin.
On my 2019 silverado high country 6.2 i put a 2 in leveling kit in the front and the noise is gone.
  • Thanks 1
Neither. That assembly is the CV shaft/axle. You buy it as one unit. The stub shaft is the short axle shaft that goes from the differential to the end of the axle where the Cv shaft attaches.
https://www.rockauto.com/en/catalog/chevrolet,2020,silverado+1500,5.3l+v8,3444633,drivetrain,axle+shaft,10439
  • Thanks 1
I’m glad to hear there’s a fix. Thanks for sharing. I’m looking at a few options with UCAs.
On 12/18/2021 at 7:46 AM, Chris Panke said:
1) Share your information sources.  Per GM regional brand quality the SU4 axle is made by American Axle and the SU5 is made by GM (most likely subbed out to the former Delphi plant now run by Nexteer). 2. Country of origin isn't known and to be quite honest doesn't matter as same manufacturing processes are used around the world.
3) Haven't seen anyone share yet which axles go on the Trail Boss or if a Trail Boss has the same issue. It is relevant because the factory lift on the Trail Boss is same as GM factory lift that is sold as aftermarket accessory for non Trail Boss models. 4)  It comes with a different diameter cv axle to compensate for the increased angle at the differential.
5) I had the dealer install the lift with the new cv axles and so far the noise is gone. GM Engineering won't authorize repairs of replacing SU4 axles nor differentials as that doesn't fix the issue. But it seems a different axle part number (oe- different axle design) may fix the issue. So in that perspective it is relevant to know if the Trail Boss axle is yet a different part number with corresponding RPO code.
Your using axle, CV, and differential interchangeably so I am somewhat confused, but I'll try to make do with that I can gather from your post.
1)  I apologize, I misspoke when I indicated the differentials were made in Mexico., I should have been clearer and used the term "utilized".  From prior posts over the past 2 years on this website, and others, information has been provided that indicates one of the differentials (not axles) is predominantly used in Mexico trucks while the other isn't.
2)  I whole heartedly agree, the same manufacturing tolerances are required around the world per given manufacturer.  However, the SU4 and SU5 are completely different designs from completely different manufacturers so there definitely WILL be differences in the two differentials that do not allow for an apple to apple comparison.
3)  Trail bosses have the same issue because its not the axles, its the differential that's the issue.  If you have proof otherwise, please post.  For your reading pleasure, or if you get bored, please check out this informative post on the SU4 differentials.  I believe you will find some clarity there.
4)  The Trail Boss axles are not any different in diameter, its their length, as shown by users who have measured and compared the two.  If you have quantitative proof otherwise that shows them to be wrong (and please tell me its not from the mouth of a dealership technician or parts salesman), please post it since I would much rather admit I'm wrong, learn the correct answer and move forward, than to sit here and give out false advice.
5) If new CV's cured your issue, then you didn't have the same "Jingle-Jingle" issue as others.  The issue is internal to the differential and not related CV length or design.
Understood now.  Your meaning is the mating part of that joint by located within the differential assembly.  That rockauto link has some interesting detail there and honestly, I hadn't thought to reference them as well for this issue.  Based on the image, it looks like there is a different stub shaft based on the front supplier axle code.  The SU5 supplied axle is okay to order just the stub shaft but the SU4 supplied axle requires you to order the half shafts along with the stub shaft.
So it seems there is definitely a design difference between SU4 and SU5 axles.  According the rockauto description, the SU4 has a larger lead in chamfer.
I really hope the stub shaft repair on your truck is the fix and that GM Engineering can get off their ass to approve this repair at the dealerships.  Good luck and thank you for the good explanation.
Also, I failed to mention that the "Jingle Jingle" is only experienced in the SU4's, not the SU5's, per GM documentation.
Per
"Some customers may comment on a squeak or chirp noise in 2wd that goes away in 4wd. Some people may also describe it as a metallic jingle, ringing, click or tick. Condition is easiest to duplicate in warmer ambient temperatures, after approximately 30 miles of driving and is barely audible. Technician may notice that the noise seems to be from the front left axle seal area. This information only applies to the SU4 axle in pick up applications AND all utilities.
This condition does not affect durability and or operation of the vehicle but may be annoying to some customers. Test drive the vehicle and confirm the noise is in fact as described above and inform the customer that as soon as a repair is validated this document will be updated communicating that repair to the dealer. "
Edited by Gangly
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
