We didn’t get a ton of snow, maybe 6-8”. But it’s blowing around everywhere at 35 mph++ so most surfaces either only have a dusting, OR 2 foot drifts. Not much in between. 😆
The snow we did get also happened to lay down on a nice layer of ice and freezing rain so the cleanup is taking awhile. 20 degrees and wind chills in single digits don’t help.
Worst part is definitely the shock to the system since last Monday it was 72* and me and my son had a nice drive down to the creek in T shirts and shorts.
Probably 8-10in where I am, lots of blowing snow. South and east of me got 12-20in easy in places. I drove through Durand, WI this morning for work and they had at least 15-20in there as well.
Tonights low is below zero again and then we'll see low 50's by the weekend lol.
We have one more cold day and a bit more lake effect tonight. It's 18F right now with a windchill of -10F. Wind has died a bit after the sun when down. That was some real wet snow. My back is trashed. LOL
Going to get down to 5F tonight with tomorrows high as around what it is right now. May break freezing Wednesday.
Two nights right at 32*. The Thursday 92, Sunday 99
  • Haha 1
We're getting the tail of the storm here that totaled just over 46 inches of rain in Maui over a few days last week. We've got flood watches in effect. This is also unusual for this time of year as winter turns to spring. I mean, it's often rainy, but this is a LOT of rain. The rain is also how we turn this place into mecca between mid-April and October.
Winter got its final shots in on my wallet over the last week. Last Tuesday it was kind enough to hail and punch holes in the roof panels of my gazebo. Then this Tuesday the cold snap finally did my original 2018 battery in. No warning, no fade to failing, just woke up today and she was gone. Charger wouldn't even touch it. Tested at just under 12v and all of 22 CCA, lol! Went to Wally and got an Everstart AGM for $170. Not too bad. But I am done with winter now.
Local news tells me today that while this year has been twice as snowy it is still 1-1/2" below seasonal average. It was pretty light last year.
Talked to someone yesterday who has had a mountain cabin for years. Usually 4-6 feet of snow there, no snow now.
Very dry, scary for fires.
I used to go up to St. Mary's Glacier when I was younger and it was awesome. Right up to the road. Last time I was there, it wasn't much of anything.
78 degrees today. Brick house gets pretty hot in the sun and holds it forever so we kicked the air on. If nothing else to make sure the 1997 vintage unit still works. Unfortunately no fan but just needs a cap which I ordered on Amazon. It’ll arrive just in time for it to drop back into the 30s. Least I won’t sweat installing it! 🙄
  • Haha 1
Roughly seven inches of rain in the last say 60 hours or so and now back in the 40's. We are supposed to have a few days of clear then another four day rain wave. It's a bit more than spring showers. Pretty sure we are no longer in drought mode. Standing water in fields. Rivers out of bank. My sump system is running.....allot.
We got a few inches Wednesday, need moisture bad. Worst dry spell in 10 years here.
We had a brief shower by Texas slang resulting in about an inch. Along with a front that brought a bit of a breeze up to 35 MPH. And a slight drop in temperature from 80 to 50 degrees as the front leaves. A normal week by Texas standards.
Another whacky weather week up here. Tornado warnings in 4 of the last 5 days. Phone alert at 1:38 AM for the first one took a few years off my life. The others have been in the late evenings. Thankfully no damage. Just lots of rain. We had already exceeded the monthly average in the first 7 days. Not sure where we stand now but has to be a record.
I’m sure @Grumpy Bear has been seeing similar crap down by him. Tonight’s band was 1000 miles wide…
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
