Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well.
My bad...
But thank you a lot with the help as well.
I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh).
I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera.
I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.
Once I get it 100% done I will post here result....
Nice! I wish I had something to put them on. Someday when the engine craps out in our '86 Grand Marquis I guess. My truck is diesel, so won't need one for that.
The Merc is at 315k miles right now with zero signs of slowing down!
I'm more of an Edelbrock guy, though. I like super-simple.
That's a beautiful thing!
The one I'm converting now is my winter beater. Only has 114 HP at the crank stock, LOL. 2.3L 4-banger. Pathetic in the power department, but it gets me to work all winter.
Register a new accountSign in
