If you regularly hit bumps that cause your truck to jump then you probably should have your alignment checked on a regular basis.  I agree with others that your tire pressure is too high and will lead to uneven wear and a less comfortable ride.  Your shocks could be worn or faulty and ask to have them inspected while getting an alignment.
Also, the oils in the rubber in the tires starts to dry out more when they get towards 3 years old, so they tend not to be as soft and squishy and quiet as new anymore.
23 minutes ago, DeePa said:
Shocks are fine. End of story.
Fixed that for you.
Let's see, nothing has changed but the tires yet it is the shocks :rolleyes:
Tyler
1 hour ago, REDOO2000 said:
80 psi is max
depending which load rating you have, I think your 2 rear tires can hold between 6100-7000 lbs total. That is more than your entire truck weighs and 1000-2000 lbs more than my OEM rear tires can carry. So bottom line is this, you have bigger heavier, stiffer tires, with no load on top. Of course you are going to bounce around on large bumps.
What is your load rating on the winter tires? are you running the stock ones? I can bet that is why you notice such a difference with the summer tires.
There hankook dynapro atm 113 load rating
265/70 17
265/70 17
That would give you a capacity of 5070 lbs on the rear wheels. Significantly different than your summer tires. I think you are just feeling the difference between two very different tires.
If you run your OEM tires in winter, they are P rated. A car tire. When you bought your Hankook's, the tire shop would not dare sell you a P rated tire for a truck unless you specifically requested it. They would have sold you an LT tire, which is a much stiffer tire. Rancho's on the Z71's ride a lot stiffer than the regular suspension, but I preffer the ride. The truck handles well, like a sports car in comparison to a floaty, soft, body-roll filled standard Z83/85 suspension. Being that you have 17" rims I cant see them selling you an E-load tire.
The Culprit is your Failing factory Rancho shocks that come on Z71 package trucks.
They become Pogo Sticks after a certain period of time or mileage.
Replace with a good aftermarket brand, ie Bilstein, Eibach, Pro Comp SS etc and enjoy the ride! :thumbs:
I was waiting for Dan to show up!
So, why did he not notice the shock problem with the winter tires on then?
It's a 17 with 23000. If take it into the dealership and have them go over it. If it's the shocks they're covered. Everything is under warranty...
Sent from my Pixel 2 XL using Tapatalk
You know me all to well Andy! :thumbs:
Because the internals can give way at Any time rendering them worn, blown, useless or whatever term is appropriate.
Here is a picture of the Rancho shock at only 5300 miles.
If it looks like this on the outside what is happening on the inside?
And a short video of what happens to them when they fail.
Nothing more than a pogo stick which is exactly what mine turned into.
8 hours ago, REDOO2000 said:
Could shocks in 2017 z71 Silverado with 23000 miles be bad already?
Yes, that's about when the first black OEM shock on my 2014 puked oil.  The second one went at 32,000 miles.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
