Help identify an issue - Skipping/Shaking
Very happy to hear that. I would be interested in hearing what trans temps you see as normal driving after the mod. Thanks for the post.
  • Replies 38
Its been a week, truck is running great. Trans is feeling strong and doesnt skip a beat.
Even on a mid 80s hot day going home with traffic i got 170 max. Normal temps are at most 145 on average.
I also used a bottle of Techron fuel injector cleaner and i swear no more misfires.
I was surprised it worked. I will be using it every 5k miles going forward.
Thermostat doesn't prevent transmission from getting hot--rather the opposite--it allows it to get to operating temperature where it is most efficient and easier on the syncros, etc.
That's a great price for a new trans. Can't beat that.
If mine started acting up, I'd take it to the dealer and trade it in ASAP. The loss on trade in is probably less than the trans itself and then I can start fresh. So long as I can limp to the dealer and clear the code so it passes inspection, let GM have at it.
You are right but many people see high operating temps 200*+. The big power vehicles have no thermostat and big single or dual coolers and max temp of never more than 180* but operating of 150*. My truck gets to 120 in first few miles. And engine temp of 180 in first mile. The engine brake that others talk of shows in data a 20 degree increase in temp. So to think a operating of 150 and one brake and in that 2 seconds you are at 170+ fan on and trying to cool. Issue is the stock thermostats is too hight for anyone but maybe a eskimo.
Remember if you read the official 6l80e bulletins it says after flush/fill to start engine and shift to neutral the pump will cycle the fuild around. But how can it flush the lines of that fluid? Where If there is a lower thermostat or no stat the fuild is always cooling and filtering.
If i had a thermostat i would want a 120* warm but out safe for my other controls to work and at lights I would know the fluid cooling.
If you're building that much heat in the transmission, having no thermostat isn't going to prevent the temps from going above 180. 180 is the normal operating temperature and when the t-stat is fully open. Now having no thermostat is likely to cause more wear and stress on the transmission as it is running with fluid that hasn't met its target viscosity. This means reduction in MPG, more wear on the internals, and likely to cause blockages and other problems as it isn't warming up enough to burn off moisture build up/accumulation. It is also normal to run regularly around 155-165 as the thermostat is partially open but not wide open until 180. That does not mean that normally running temperature is 160--that just means the thermostat hasn't reached it's target temperature yet--much like the t-stat of the motor running at 210*.
Having a dual cooler with a T-stat is a better platform--the transmission can run at normal operating temperature but can keep cool when the heat build up exceeds what a single cooler would be able to manage. The fluid specified is capable of the higher temps than just 180* and the truck would warn if there is an overheating problem--much like the coolant that runs through the motor. The motor runs at 210 with the t-stat wide open but can comfortably run at 10% above that temperature as well and still be within normal operating spec without any long term concerns.
If you're hammering on the trans to the point where it is constantly running near the peak of its operating confines, you're using the wrong truck for the project. That, or you need to subsidize the cooling system with additional oil coolers. Not having the thermostat is outright dumb and ignorant.
Sorry but the the pros as well as GM disagree with you. this is not what my emails and the specs from GM say on D6 or these trans. also what you say about running 210 if it was 10 over it is still fine but a light on dash. In fact we are going over some of that it in the tune with the "hot" table and what we can set that to also. but for a "new" oil type to be spec and to say then it can are two different things. But no d6 break down vs temp rate state other wise. also if you follow so of the big power builds, where guys are using a 6l80 or 6l90 and have $10,000 trans you will see they make a goal of 150ish temps MAX 180.
As far as engine coolant that is different there are tuning table that change everything based on a ect temp. So this is important. I need 180*. As I said a minimum operational temp I agree with a statement like but there is a point of a compromise to the fluid and the wear and protection of parts.
If you would like I will post the articles and emails as well as the(If I can ) tune blog on trans tuning.  Even the Circle D article for hot rod talks of this. as well as AMSOIL did a video on it in a stock truck.  How many people having trouble with there 6speeds and 8 speeds. I will trust the people that have made then work as well as the ones that engineer and test them.
16 minutes ago, 1SLOW1500 said:
"ideal" is 180. Much like ideal of engine temp is 210. Doesn't mean running it over that temp is going to cause problems. Sure, fluid will sheer sooner and have a shorter lifespan--it's a consumable, replace it after X miles.
What is this body of text from? Something advertising additional products from their company? I trust an engineer from GM before someone selling me a product to help with a problem that isn't really there. Failure in these transmission is due to a 1:50,000 chance--most likely due to manufacturing. Probably a 1:1,000,000 chance it's due to over heating. Again, if the load you're putting on it is creating that much heat, you have the wrong tool for the job. These are half ton, grocery getters, weekend home depot runners. Sure, they can pull 10K lbs, but in reality, they are not designed for it long term. That's what the HD's and real/full size trucks are for. Yes, you can make the truck exceed capacity or run at it's peak capacity, but you're just putting band-aids on problems that shouldn't have been there in the first place if used appropriately.
These are not race cars, these are not off road rigs, these are definitely not heavy duty or full size trucks. If you're creating that much heat to damage a transmission, you're using it a manner that exceeds GM's target market for these vehicles.
that is from Circle D invoice. that is why I blocked out the top and bottom.
I just checked 5 sites and every single one it the same info heat kills stall under 200 or under 180. and cooler bypass it. they run hot.......
Oh also interesting gm changed design from trans cooler lines into the radiator to not in the radiator and in stead in the AC condenser(like mine) seams they knew the heat was a issue. But I am checking with my GM contacts on that one. also says 2014+ they stated adding the thermostat.
Can't add the other sites unless you are a member.
Oh this cart seems about right as Amsoil video shows 40k miles all stock yukon with burnt oil and debris. and the few Gm-truck guys had over 50k miles and trans issues. so by this chart us 200-210* guys need changes every 25-30k miles. And how many people are doing that????
hrdp-1110-02-o-technical-questions-and-answers-temperature-graph.jpg?interpolation=lanczos-none&fit=around%7C660%3A495
https://www.g8board.com/forums/6-drivetrain-tech/146721-anyone-know-6l80-running-temp.html
https://www.corvetteforum.com/forums/c6-tech-performance/3848346-suggestions-for-lowering-6l80e-trans-temp.html
https://www.camaro5.com/forums/showthread.php?t=190146
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
