Installed the 2" lift kit bilstein 6112 shocks and springs on my otherwise factory 2015 gmc sierra crew cab 6.2 SLT.
Kit number was 47-273702 and included both front shocks, springs, mounting cups/hardware etc.  I put a set of 5160 rears on it.
These showed up and wow!  Shocks are huge diameter almost 3".  Giant pushrods.  Everything looked extremely stout, bigger and equal quality to the $2k+ set of fox I put on my last cummins.
Installation went smooth, no hangups although I am surprised at how fast GMs rust given the truck is 4 years old.
I've driven 800 miles so far so presumably everything has settled nicely.  The top setting (4 adjustments) gave me 1.8-2" of lift, which makes the truck appear level in stock form.  Ride is VERY controlled, does not feel stiff to me at all, but the bounce and rock from the stock ranchos is now completely gone.  Quite fun hitting speedbumps and joints quick, the truck just absorbs the hit and there is no jounce or jar.   Very stable.   I would even venture to say the ride soaks hits better than the 2.5 fox setup, although this truck is lighter and independent front so never a fair comparison.  Overall just wanted to post this up since I did not see many reviews for this product related to GM trucks, so I was a bit weary on the initial purchase!
  • Thanks 2
Where did you buy your kit and how much?  I've been considering this so I appreciate your review.
Thats the best part, only $600 for both fronts, includes shocks and springs etc.  I bought it from battle born offroad but have no connection to them, so I would just find the best price.  They had a coupon code for gmtrucks at the time I purchased.  Shocks are 2.7" diameter.  The rears are a bit smaller I think 2", but they have reservoirs so should even out.
Wow Truck looks great!  I love the stance.
99BB congratulations on your 6112's.  Nice write up and they look good.  Bilstein makes good products for the money.
Thanks for the write-up and review. I have a set of 6112's in garage waiting for installation on Tuesday. Been back and forth on what setting. I also was thinking setting #4. Installer suggested 3# setting and that made me second guess myself. Have a few days to deceide and 2" blocks for rear if I go #4.
Glad I looked for a 6112 thread before starting one. I also ordered 6112 front and 5160 rears from Battle Born. The 5160s arrived yesterday but I ordered complete, built 6112s so I can install myself without a spring compressor. I had Battle Born assemble the 6112s on the highest setting. I bought new block for the rear that will raise it by 3/4" so I should still have some rake for towing. I'll install everything later in the week.
One thing I noticed about the 5160s is that the steel bodies seem to be machined but with no coating, I'm wondering how long they'll take to rust.
Clear Coat would be best, but you might take a look on Amazon at two products I've used to keep corrosion down on sleds, quads, dirt bikes, spare tire hardware , hitch receivers, tools. I've had ACF -50 for awhile and just ordered another can of Corrossion X.  I like Corrosion X better. I've never used on shocks, but don't see how it could hurt. Obviously keep that far away from brake pads, rotors.
I have to drop truck off later today and have changed my mind 10 times if I want to do 3rd setting and leave rear alone or 4th setting and add 2" block in rear.
Well, it your truck and you can set it up how you like.  But if you want my opinion, use the 3rd notch.  It's plenty for a 33" tire (maybe 34") and is easier on the ball joints, steering components and CV joints.  Plus you don't need blocks for the rear.
That's how I plan to set mine up.
Nice review and post Doug. Thanks for sharing.
These have been highly anticipated since 2015 when they were introduced. I gave up on them and went with 5100s.
Painful as to why it took 4 years for them to be released on the GM trucks.
Question is, are they really worth the $400 more than a front set of 5100's ?
My 5100s provided a tremendous positive result over the worn out Ranchos on my truck.
I dog on the Ranchos any chance i can get!     :loser:
Your ride experience compares to the feel of the 5100s.
Maybe the spring is softer for these than the factory spring for the 5100s.
That's the way I'm leaning.
I wish Bilstein would offer an equivalent bodied rear shock to accompany this 6112 front.
The 5160 is a 5100 with a reservoir. Smaller body and rod.
There is so much less weight to damp in the rear, why would need a bigger shock body and piston?  Even loading up the bed and putting  1000 pounds on the hitch barely balances out the weight.  For road driving, 5100 rear is fine, for off-road, the 5160 provides additional cooling.  Are the rear shocks from other manufacturers bigger?
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
