AT4 vs SLT z31 Package?
So I’m leaning on my inner Millennial, barely making the cutoff at ‘82, in needing
someone to push me in the correct direction on which of these to purchase.
Both have their pros and cons in my opinion but I’m hoping someone wiser, or not, can just give me some words of wisdom on which way to plunge.
I love the fact that both can carry some beefier tires, lift kit, etc but I think I’m caught up on the “set” interior options with the AT4.
- is it worth it to get the 6.2L or will some decent mods give me that jump I need getting to kids soccer practice. Don’t judge, you know your ass likes to kick it pulling out of the Girl Scout lot ?
thanks in advance gents..
semper fi
X31\Z71 has no lift. Same ride height as regular 4x4.
I'd get a regular X31 SLT optioned as I want and then get whatever lift and tires I wanted.
Get the AT4. Better interior options, and looks MUCH better without all that ugly chrome. I’m a 1982 model, too, and chrome is for the Boomers, bro! ?
Also, the Ranchos on the AT4 are monotube, which are a step up from the horrid twin-tube Ranchos on the X31/Z71. I have a 2019 Z71 RST and the shocks are really poor.
As for the powertrain... this is tough. Not only do you get more power with the 6.2L, but you get the 10speed, too. I have the 5.3L / 8speed. It’s a surprisingly quick and responsive powertrain.
As much as have the extra power of the 6.2L would be so fun, I’m not sure I would shell out the extra $ for it, just to enjoy the time-to-time fun of mashing on the pedal. (I don’t tow much, full disclosure. So take this FWIW)
I went with the SLT X31 with Premium Plus package because the rebates were much, much better.
I went with the AT4, I like the interior and the lack of chrome. It came with 90% of the options I wanted already on it. Instead of rebates the dealer paid me about $10,000 to much for my trade in, GMC loyalty bonus and other things.
The AT4 already has the leveling kit installed and warranties. Rides really good. Rancho shocks are an upgrade as well. Should come with most of the options you are looking for too. I added the tech package for the cameras since I tow quite a bit. Also added the 6.2 for towing and it tows well. 10 speed only available with 6.2 and seems good so far (8000 miles). It would cost a fortune to get the 5.3 to the same power and still no 10 speed. Getting as high as 23 mph on highway 20 mph in VT mountains. All depends on what your needs are.
Yes, the AT4 only has 1 interior option (Black with Kalahari accents), but the SLT only has 2, Jet Black or Dark Walnut.  So unless you really want Dark Walnut, that shouldn't be a deciding factor.
As far as engine size, drive one of each and determine if you think its worth it.  I did and went with the 6.2 .
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
