Here's my build
Specs:
  • 18x8.5 +0 Black Rhino Chase Rotary Forged in Brushed Gunmetal
  • 295/70/18 Falken Wildpeak AT3
  • ReadyLift 1.75" Level Lift
Very minor rubbing resolved with minor trimming. I created a post on our site of the trimming requirements for those looking to go with a larger set up on the AT4: https://wheelsasap.com/gmc-at4-oversized-tire-trimming-guide/
Edited by WheelsASAP.com
grammar
  • Like 7
On 3/30/2020 at 3:40 AM, Trevor Munsell said:
285 45 22s on oem replicas. I went the budget route to get me into some 22s. Now im wanting to upgrade for a little more sidewall to either 275 50 or 305 45s. What y'all think?
Can you give some info on your wheels? Brand, spacers if any, website?
Custom Offsets. 4play cv43 gloss black. 3/8"hubcentric spacers added to order for $63. Ride great..no vibration. Got for unbelievable price.
On 5/2/2020 at 10:24 AM, WheelsASAP.com said:
Specs:
Thanks for this - great resource!!!
Anytime my friend! Feel free to PM me with any questions you may have.
On 4/22/2020 at 8:08 AM, loud_pipes said:
ReadyLift SST, Atturo Blade XT 305/55/20 (33x12.5), Moto Metal MO970 20x10 with 0 offset
991e784d7dd1d263ba13ce3d27a5bd14.plist118874e57086df09a6a99311aa0877b5.plist991e784d7dd1d263ba13ce3d27a5bd14.plist
Did you need to use spacers for the wheels?  Looks great.
Mine is a 2020 Custom 4x4 with 5.3L (NOT a trail boss)
35x12.5x20 Atturo Trail Blade X/Ts (Measure out to 34.92” and 12.52”)
2.25” Pro Comp level up front (actually sitting .75” nose High at the moment so getting a 1” Rear block put on soon).
No spacers. No trimming. No rubbing (although to be fair, I deleted the rock/mud guards as soon as I got her)
Mines a 2019 Silverado RST
I went with a 3" Superlift
Wheels are a 20x10 -18mm Fuel Rebel wrapped in a 285/60r20 Nitto Ridge Grappler
That comes out to be a 33.7" Wheel setup
  • Like 7
Hey thanks for the info! I got a couple more questions tho?. Did you need the spacers to clear the calipers or just for the look. Were the factory wheels studs long enough to take the spacer and the wheels no problem?
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
