Have a 2020 1500 RST. Stock suspension. Looking at putting a 3.5” - 4” kit on the truck.. want to run an aggressive looking 35” tire on stock 20” wheels but don’t want serious rub.. anyone running a similar setup? Any pictures out there?
I installed these awhile ago but this is my 5.3 Elevation. It is levelled (in the rear). 20x9 Fuel Rebels on 33" Kendas.
Edited by diambo4life
Here is my setup
Fuel Vapor 20x10 -19mm offset
Nitto Ridge Grapplers in 275/65/20
I put on ready-lift 2inch leveling kit
did a mudflap bracket delete with trimming the innermost portion of the flap and zip tied the liner in one spot.
No rub at all
Used this forum to pick out my specific wheel and tire set up so I’m returning the favor!
20” Vossen HF6-4s 20x9.5- +15 offset.
275/60R20 Falken Wildpeak AT3W.
it has a 3” Superlift lift kit. The tire size is same as stock on the stock 20” OEM wheels. There is zero rubbing at full turn. This setup gives a similar look to a leveled AT4.
Edited by Trevor Towers
Adjust wheel specifications listed erroneously.
20” Vossen HF6-4s 20x9 - 0 offset.
Looks great! Do you happen to have a photo down the side showing how much poke there is?
I do. It should be somewhere around 1” of poke over factory. Also added a picture of the clearance at full lock. I wasn’t interested in going any bigger than the stock tire sizing because I didn’t want to impact fuel economy too much with weight, overall I believe the new setup is just a touch lighter.
Thanks, that looks good. I actually had ordered these wheels a few days ago but in a +15 offset and 9.5” wide. Didn’t realize they had the other offset and widths available.
Vossen has a custom sizing program, you can get them in configurations from 8.5” - 12” wide and offsets from 0 - +48mm. But I just double checked my receipt, it says 20x9.5in +15mm offset. I called the sales person to confirm because he was telling me 0 offset over the phone previously, I think he was just mistaken. He said that the 20x9.5 +15 is the STANDARD size for these. I’ll update my post. What kind of tires are you going to fit on your vehicle?
Here are some more pictures for you as well. I included an image of my city MPG in just normal driving to show I can still maintain essentially the same MPG I was getting before. All city driving.
Oh nice, thanks! I have some Toyo open country at3 275/60r20 im going to put on them.
Here is mine.
2020 Silverado LTZ Z71 4WD
Bilstein 6112's in front, 2" level
Bilstein 5160's rear with 1" block
Fuel Sledge 20x9, +19mm, ceramic coated
Toyo A/T III, 285/60/20
No rub. Tires stick out past fender by about 5/8". Very happy how it came out.
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
