12 hours ago, luke1333 said:
Truck looks good! Did you do the clear reflectors on the headlights?!?
10 hours ago, Traction said:
More pics of headlights? you do them yourself?
Thanks. Yeah did them myself.. More of a pain in the ass removing the grill to get the lights out than it was to do the work. Used klearz lenses. Was torn between clear and smoked ended up going with clear kind of wish I went smoke to go with the all black look. Hopefully don't get scalded for posting these in this topic. Didn't take much with the lights apart unfortunately
  • Like 4
Will post another pic with details.
2021 LT 4x4. NO level and only minor trimming on the interior of the front mud guards. 35 x11.5 x 20 Nitto Ridge Grapplers. Drives fantastic.
Edited by SAINTS 504
20X9 10 offset American Outlaw Railcar Wheels
275/60R20 Goodyear Trailrunner AT
2" spacer up front, 2" block in the rear
Edited by Method2Madness
Looks great and wish I would have known that before bumpers and grille got swapped on mine last year! 🤦‍♂️
What, if any, go to brands do you turn to for "higher end" wheels for your trucks? I know of BC Forged, Vorsteiner, Vossen options.... any that i'm missing?
I'm having a lot of difficulty making a choice!
On 9/16/2019 at 9:57 PM, STX30MAC said:
4497942f7bc181cc39de9480ac56ee2d.jpg5f153543b059893be7084e24228f788c.jpgd408d7c903d5288c38bb1b684ffce4ec.jpg
6in BDS
35x12.50 Nitto Ridge Grapplers
20in factory wheels
What spacers are you using to fit these 12.5 wides? Thanks! Great looking ride...
Stock suspension with Bilstein 5100 front shocks set to medium setting (0.6inches of lift), rear 2 inch block replaced with 1 inch block to lower rear 1 inch. Removed bracket behind mudflap to get rid of rub. Tires are Nitto Recon Grappler 35x11.50r20. Wheels are Factory Reproduction FR94 Trail Boss replica in gloss black finish 20x9 +15 offset
Looks good! How the recon grapplers road noise compared to stock?
So far great. But new tires always are lol. I had 22,000 on the 18" Duratracs and the noise was terrible. I think the Ridge has the best sidewall design of all the Grapplers but the Recon was more of a street tire which is what I preferred.  My first choice would have been the Exo Grappler with the 3 peak snow rating, being that I am in Michigan but I didn't care for the sidewall design. I am better off to get a dedicated snow tire for the winter anyway but I have driven on some snow and ice, so far so good.
Thanks!!
2022 Denali
4” Readylift SST
295/55/22 ridge grapplers
Stock 22” Denali wheels
Thinking about going black on window trim and have mirror caps (white) on the way. Plan on getting rid of chrome on the running boards and painting the hood filler trim white as well.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 766 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
