21 hours ago, Ezekiel2517 said:
I have a max trailer package on mine.  It has no 4 pin jack at all.  The absurdity of that aside, would the putco one still work in my case?
I have max tow and it has the 4 pin. Can you post a photo of what yours has next to the license plate?
Edited by bdsilverado
On 1/27/2020 at 10:13 AM, Rich Kesteloot said:
I purchased this with the add on module for my 2019 GMC Sierra Denali 1500.  I tried the curt adapter and I tried hardwiring as Opt 7 shows in a youtube video.  Both of these installs disabled my sensors and cross traffic alert thinking I was towing something.  Does anyone have a good remedy to solve this.  I contacted Opt7 and they said just send the product back for a full refund but I really like the look of the lights but losing all safety features is a real bummer.  Anyone have success with this?  Or suggestions.
get the putco adapter. that is what i used on my Opt7 and rear sensors now work
Mine has the trailer camera package so I guess the video Jacks took the place of the 4-pin.  Seems stupid to not include that.  20200201_194238.thumb.jpg.e22bd610318c87ec63689320aa98af27.jpg
  • Sad 1
Ohhh that's cool. ?.  I'm assuming you checked the glovebox and havent seen the 4 pin harness but i recall the manual saying something about this issue. But dont remember since it didn't effect me. Maybe they put it behind the bumper right by the hitch?! Idk.
They gave me an adapter.  I'm probably gonna wire in a permanent one though.  An adapter feel so janky for this truck.  It will do for now tho
Has anyone used this harness while installing a LED tailgate light bar? I figured it looks pretty neat and would eliminate having to splice in the reverse wire.
https://www.amazon.com/CURT-56584-Custom-Wiring-Harness/dp/B007EA6WQU?pf_rd_p=5cc0ab18-ad5f-41cb-89ad-d43149f4e286&pd_rd_wg=im5Kn&pf_rd_r=E95TPS65B3NMNAHNGGYY&ref_=pd_gw_wish&pd_rd_w=ofRKx&pd_rd_r=3b32a8d2-05b8-4981-9eac-0c566b218530
I am thinking of getting the OPT7 Redline and using this, since I have a custom trailboss I'm guessing there's nothing to interfere with.
On 7/26/2019 at 12:34 PM, BlackLS said:
I have the Putco Blade and used the Putco "Plug and Play" harness which connects to the trucks tail light wiring harness not the trailer lights.
I tried the Curt harness from Amazon but my truck did not like it, my screen kept alternating between "Trailer detected" and "No trailer connected" over and over until I disconnected the harness. Also tried plugging the light directly into the trailer plug but had the same problem.
Putco harness info: Blade Quick Connect Harness for 2019+ Silverado/Sierra 1500 SKU: 529005
Link https://www.putco.com/529005
What exact putco model lightbar is that and did that harness allow the reverse to work without splicing? Ordering one for my 2019 and want to make sure I get one that will work. Thanks
How does Opt7 connect to the Putco adapter? Is there a 5 pin connector, or did you use but connectors?
  • 4 months later...
I have a 19 Trail Boss. I got the rough country quad row led lights for under that tailgate. I then got the curt plug to tie into the trailer plug lights behind the bumper. My truck has that advanced trailer package on it so that did not work right. Found a lot of people said to get the Putco adapter that ties into the tail lights. I got that and the light bar works perfect and is nice and bright. The catch is it only works when the trucks lights are on. Parking lights or head lights. When the lights are off only the brake light works right. the rest just kind of flicker and only part of the bar lights up. Any idea what is up with that? Could it be because it has sequential turn signals so it is just not going to function unless the lights are on?
Edited by collins5004
I have the Putco harness and opt7 light bar and everything works perfectly including the sequential turn signals.  It may be something with the rough country setup.
Ok, that is good to know. I am still waiting to hear back from rough country. I will try to get ahold of them again tomorrow and see what they say. I hope i just have a defective light because i really like this light but do not want it if it doesn't work right.
For those with the Putco setup, what size bar did you go with?  I assume the longer bar (60 inches) will look better as it would fill most of the space.  Also, did you go with the Red/White option or the Red/Amber/White?  If I recall correctly, why would you choose the Amber option if the rear turn signals and four ways are all Red, unless it is trim level dependent, as I am in an LTZ?
Lastly, I plan on purchasing the 529005 adapter as well; so how long should I plan on the install taking?  Do I need to remove the tailgate?  Is it just an adhesive backing?
Sorry for all the questions, just looking to make sure I know what I am getting into before spending $300.  Any additional pics not already shared would be helpful.
Thanks in advance!
I went with RED /White / Amber , same on my last truck .   amount an hour - give or take .
Hello guys. I’m new here. This topic is the reason I joined. I purchased the Redline tailgate led to install on my 19 Silverado High Country and I gotta tell you, it doesn’t work. I bought all the adaptors, all their modules, everything you can think of. I tried all the suggested versions of mounting this. Still nothing. I took the truck in to the dealership thinking is something wrong with it. Not that. The electrician there tried it on an earlier year truck and it works perfectly. He explained to me that the new trucks with all led lighting are different. Not even the module from Redline that’s supposed to fix the problem on new trucks doesn’t work. I’m about $160 into it and all I got is a bunch of parts. Any ideas?
    • A little girl said her prayers every night before bed and she asked G d to watch after each person she loved. One night she forgot to pray for her babysitter and her babysitter died. A few days later she forgot to pray for someone else and they died. The next night she forgot to pray for her dad. The next morning her dad was terrified. A bus almost crashed into him. He almost fell off a fifty foot ladder and almost wrecked on the way home. When he arrived home, he said I had a terrible day. His wife replied, “You think you had a bad day? My aerobics teacher died during class.
    • Nice! I had one here, once. The car dealer I used to haul for stopped by with it. That was over 10 years ago now. Those are SUPER rare these days, especially up here! Never even see them at car shows anymore.   https://postimg.cc/0rvcNZ1W
    • I remember watching one of the auctions on TV. It just happened that they had two little red express trucks. My brother bought one new in 1979, still has it. So I hung on to watch them cross. The retro redone example brought more bids and went for more money than the original one did. My brother has redone his 3 times and raced it. He’s now in the process of making more tame for cruising.
    • I always upgraded the suspension and steering components - bushings and ball joints, and had older cars that I could out-corner ANY modern car with. I used to be able to take my '78 Cutlass on off-ramps at stupid speeds and make the sharp MA corners without even squealing the tires. So much fun. My '72 El Camino must've had work done by the previous owner, since that thing seemed to handle even better than the '78.   I think the suspension & steering on the '72 was much more advanced than the '64, so that probably just made a good system even better.   I'm the same way with vehicles. I hate having to worry about the paint on my '93 W250 Cummins. I'm not used to that, lol.   https://postimg.cc/mzKr55sY
    • BEAUTIFUL!! That a Cutlass F85? Or 442? My side-ID skills are lacking thanks to failing memory, lol. Love that color & year, too!   Yeah I was never big on entering my own stuff, but I always liked seeing what everyone had, the rare models, and what's been modified. That was always fun. These days I have barely enough time to do what needs to be done at home.    Oddly enough, here in MA there are more car shows than ever in history! You'd think up here it would be dead, but it's bigger than EVER!          Took the 940 for its maiden voyage with the carburetor. At first I couldn't get out of the yard! This originally had the "Bosch" system (our other 940 has Regina - single fuel pump in fuel tank, and space-age-looking ignition coil on driver's fender) - that has dual fuel pumps. One in the tank, and one under the center left of the vehicle. I had unplugged the external one thinking I wouldn't need it with the carburetor ... but the way I have the pressure regulator hooked up, 90% of the fuel volume is going back to the fuel tank, so cranked all the way down, the regulator is only supplying a hair above 3.5 PSI to the carb. Turns out the in-tank pump (15 PSI alone, instead of 45) couldn't handle the load. Plugged it back in and went for a rip. Ran great!   Throttle response is always amazing with carburetors. ZERO delay that no FI system can reproduce. Also fires up in half the crank rotations as before. Low end power was DRAMATICALLY improved. There was an ongoing lean issue with the FI that I got tired of figuring out, so this is a MASSIVE improvement! Above 50 MPH on hills it feels SUPER weak, though. This is more than likely due to the timing not being advanced enough by the computer, since it believes there are multiple failures. I can live with that through the winter. Will keep me from passing slowpokes where I shouldn't and getting speeding tickets at least. 😁
