Hi guys, new to the forum, have my 2020 AT4 carbon pro being delivered next week. With that I inquired with the dealer on tonneau cover options and the only one they provided was the $600 folding soft GM one. I ended up getting it for $400 with a Costco discount deal on the truck purchase, however they wanted $170 for installation. Seeing as I have a lot of time at home right now, I’m going to save the money and tackle it myself. Any tips/suggestions on installing the GM one? If it’s a pain, is it worth $170 for the install?
On 1/30/2020 at 9:54 AM, STKSUKS said:
I work for a Gm dealer and we came across this problem. We used a hole saw and cut the holes out nice and just clamped it in place. Just as I see a few on here have done. This is on a Extang Eceed cover. We figured that if a carbon pro box can with stand a hurricane wind 2x4 it can handle a hole and a clamp..
This is what I’m planning on doing with a BakFlip G2, what size whole did you use ?
Bought the LOMAX tri-fold hard cover for my 2020 Denali Carbon Pro and can honestly say I don’t like it. It showed up with scratches on the rails, no installation instructions at all, and doesn’t sit flush which will result in serious water leaking issues. Overall, it doesn’t look good when compared to my bakflip fiber-max I had previously on my 2016 F150. It has some very sharp edges that should have been rounded off during production and just seems flimsy. I paid over $900.00 shipped for this crap cover and regret buying it. I really hope decked produces a system for the carbon pro trucks, that’s really what I wanted and can honestly say I regret buying this carbon pro edition due to the limited bed accessories that are, and will be, available.
Edited by SierraKen
Add photos
WOW....I almost pulled the trigger on that till I saw the clamp option so I hope the Rolver works out better.  I'm with you on the Decked system.  Been bugging them to come out with one on their IG page.  LOL
Hi guys,
This is what my shop did to install a Bakflip MX4 cover on the Carbon Pro bed. I hope this will give you some ideas what it takes to install the covers on those trucks. Good luck!
https://youtu.be/pKEdn_isVA8
WeatherTech released their own hard cover tonneau for the carbon pro, it looks very similar to the Lomax posted above.  Mine just came today and I'm super happy with it, definitely nicer in my opinion when compared to the OEM soft cover.
On 4/11/2020 at 5:43 PM, Shawn Garneau said:
I bought the GM Tonneau...the one that they made for the carbon pro bed. It’s exactly what your looking for...trifold, solid...it’s very well made. You can open it from the back or the front. Nice locking mechanism. I actually had installed the extang solid fold on my carbon pro before GM had finished their cover. I used some metal zip ties to attach the solid fold to the eye hooks in the bed. It was fully functional.
Hey Shawn, can you post some pics? I just bought the 2020 Sierra carbon pro and the dealership bought a tonneau cover from undercover without knowing it won't fit. I don't want to do any mods to the truck so I'd appreciate any pics of the gm hard fold one.
Sorry to jumping into conversations; however, I just want to let you know that the GM cover will required you to drill to install the clamps.  If you want no modification to the CarbonPro bed, you might want to consider clamps from MWW1 and look at the BAKFlip covers as an option.  I installed a BAK RevelvorX4 on my CarbonPro and the fit is perfect.
MWW1 - Cabon Pro Bed Clamp (2).pdf
Has your cover been water tight?  Make a drive across a rainy pass in the fall and would like the bed to stay mostly dry.
On 6/2/2020 at 8:13 AM, Bernardo Fanti said:
To be absolutely sure before I pull the trigger (brand new 2020 Sierra AT4 CarbonPro Duramax!), this is the WeatherTech that fits without modifications?
https://www.weathertech.com/gmc/2020/sierra-1500/alloycover/sierra-box-size-4th/short-box-69/bedside-storage-box-4/no/gm-carbonpro-bed/yes/?OrderItemId=2109600505
 Thanks!
Looks like the Weathertech and Lomax hard covers are identical.  I saw the concern about scratching with the Lomax.  Not sure if it was the urethane coated cover or the plain paintable cover.
Can't decide weather to be patient and see what else comes out for the carbon pro or pull the trigger on the OEM, Lomax or try to adapt one of the other covers you talented people have installed.  Hate drilling too many holes in the bed because usually my projects involve oops missed by that much.
Access made a nice soft cover kit. Easy to install and no holes cut in the box.  You have to drill holes for 1/4” bolts on to pass through the plastic cap and it comes with a drilling jig so we don’t mess it up.
We haven't had a lot of rain here to determine the water tightness.  I did look from to indise and sealed any sections that had any light coming through.  The back of the tailgate had some seapage but nothing drastic that concerned me after washing my truck.  Overall, I am very happy with it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
