On 8/23/2019 at 11:41 AM, truck_newbie said:
Does anyone think GM would/could offer this for the 2019 models?
Could? I don't know. Would? Absolutely not.  Then you'd have no reason to trade up for the 2020... ?
Hahaha, fair point.
Can anyone tell me if ACC can be disabled and normal cruise control be utilized?  If the 2020 only has the ACC available and it works as well as the Yukon did I am going to snatch up a 2019 quick.
I am not a fan of GM's adaptive cruise control at all.  Had it in both of my wife's 2015 & 2016 Yukon Denalis and it was horribly inconsistent.  Overall ACC defeats the purpose of setting a speed, if it varies with all the left lane idiots in front you become one of the left lane sheep.  So, I am looking at end of year deals on 2019 Sierra Denalis and know the 2020's have ACC.  Any insight is appreciated.
If it’s like most current products hold the cancel button to disable ACC.
1 hour ago, NOVA99 said:
So you have both traditional cruise control and adaptive as an option to use?
It should, I can't seem them going back on that it was a relatively new feature/function.
I have a 2019 Yukon SLT with adaptive cruise control and if I could I would trade the car back in for one without ACC.  The only way to shut ACC off is to not use cruise control.  There is no way to shut off ACC but still have regular cruise.  Whenever I use the ACC on trips at least once or twice per trip the car will incorrectly detect a car in front of me and slam on the brakes.  Here I am on the freeway traveling 75 mph and the next second I'm at 55 mph.  This is extremely dangerous especially if there is traffic behind me.  You have to shut the cruise off or slam on the gas to get it going back up to speed.  The owners manual says ACC may not work properly on hilly or windy roads.  Uh, hello, that's pretty much every road here in Washington State.  ACC is a horrible system that makes me not want to buy a GMC again.
  • Sad 1
Guess i can stop complaining about the k2xx 2014 - 2018 trucks not having ACC.
I'd be very surprised if the 2020 with ACC didn't have the option to switch over to conventional cruise control.  I have two vehicles with ACC and both allow you to switch over to regular CC.  The owner's manual should have instructions on how to do it.
On 8/24/2019 at 12:54 PM, Fuelie said:
Below is the reply I got... certainly not going to invest in adaptive cruise :)
its doable but its a huge job, different camera, adding a few modules, steering wheel change, cluster programming, bcm programming etc. Doable but pretty expensive :(
Define "pretty expensive"?  I'm sure it's something I don't want to pay that much for, but just curious on what it would cost, since I do about 60 highway miles a day.
Thanks!
I have a 2018 Suburban with ACC. If I had realized it when I bought the truck I would have passed on it, I hate it. I can verify that the hold the Cancel button to revert to standard CC does not work on these vehicles.
Sees the 2020 Sierra Owners Manual says that the ACC can be switched back to regular cruise, if desired.
Switching Between ACC and Regular Cruise Control
To switch between ACC and regular cruise control, press and hold *.
A Driver Information Display (DIC) message displays.
See Vehicle Messages pg 156.
When ACC is engaged, a green indicator will be lit on the instrument cluster and the following gap will be displayed.
When the regular cruise control is engaged, a (different) green indicator will be lit on the instrument cluster; the following gap will not display.
When the vehicle is turned on, the cruise control mode will be set to the last mode used before the vehicle was turned off.
And there's more, of course.
And of course, this doesn't mean that's how it works in a Yukon.  Some of GM's ACC literature indicates there may be differences in how if functions in different applications (or maybe just different ACC generations)
Edited by redwngr
This. I have never driven any vehicle with ACC till I got my 2020 Sierra on Thursday. I did not even know how to use it really well till this weekend. There are 2 different icons for ACC. One is when the ACC is active the icon looks like a speedometer with a car on the top right. The other when it's not active is just the speedometer. I read the comments above and looked at a video on how the system works. It showed to make the system not active to press and hold the cancel button. I tried this today and it changed the icon from active ACC to non active ACC. I also got a warning on the DIC that following distance and auto braking were not active in that mode. The truck worked just fine like the old cruise in my 16 had.
Yes the ACC is not standard. It comes on the Driver Alert Package 2 which is included in the SLT Premium plus package that my truck has.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
