Can someone share what the “regen” is, what it accomplishes, and how often this should happen?
I’m about 2,000 miles in and haven’t noticed it at all. Is there an alert for when it happens?
The Regen is there to burn if extra soot trapped in the exhaust system. All modern diesels have them. You may not notice every time you go through a Regen. I only notice it when my window is down or I pull into the garage and turn it off and I can smell it as i get out. Doesn't really smell bad, just different, like really hot metal as it has to heat up to over 400 degrees I believe.
Also there are no alerts when it happens. I would guess there is an alert after the process gets interrupted after to many times to say you must drive for a prolonged period of time. I have not gotten any message like that yet and I have interrupted the process a few times but typically my next drive is long enough to complete
On 3/3/2020 at 4:33 AM, HondaHawkGT said:
No more than it would cost to replace the timing chains or belt on a DOHC engine, which is a scheduled maintenance item for most of them and take as much or more  work to change. Ford has used a similar wet belt oil pump setup for roughly 10 years now on one of their engines.
I’d be willing to bet it will be substantially easier to replace than most timing belts.  No timing required for the belt. “Just” pull the tranny back a few inches and pull the flex plate and cover. New belt and reverse. Pretty hard to mess that up.
On 3/3/2020 at 12:19 PM, HondaHawkGT said:
 Yeah 20 mile trips are fine. I mainly meant it as a cautionary thing for anyone considering the LM2 and are kind unsure about it. Some people do a ton of short trips in these newer diesels and end up with a ton of problems because they don't understand just how bad it is for the expensive filters on these things.
On 3/3/2020 at 11:13 AM, redwngr said:
Because water is a byproduct of combustion, and water will condense out of the exhaust stream when the engine and exhaust or not hot enough.
This is true for both gas and diesel engines.
It's not the start and stop that causes the problem -- it's the cold running / not running long enough to get warmed up enough that the moisture can be carried out.
This is good stuff guys, thanks for the info.
Next question... Does the natural climate make any meaningful impact towards this "issue/problem"? I.e. I live in Houston, TX where it's rarely ever freezing and usually 80-90+ degrees out. Would these short trips become a non-factor? Systems may warm up extremely quickly (and/or not cool down as quickly). Or Be slightly less of a factor than living in cold climate... or have virtually no impact on it being warmed up to the point short trips will still cause this "existential threat" to the engine?
Thanks in advance
Edited by Duramax3oh
Next question... Does the natural climate make any meaningful impact towards this "issue/problem"? I.e. I live in Houston, TX where it's rarely ever freezing and usually 80-90+ degrees out. Would these short trips become a non-factor? Systems may warm up extremely quickly. Or Be slightly less of a factor than living in cold climate... or have virtually no impact on it being warmed up to the point short trips won't cause this "threat" to the engine?
Thanks in advance
Too many variables to have a firm black/white answer.
How long are the trips?
How much (cool down) time between them?
Does it also get used for longer runs?
etc ...etc...
Imho, everyone is overthinking this.
All gas/diesel engines need to be warmed up to work most efficiently and to not have issues with condensation.  OTOH, the number of vehicles that never get warmed up must be very low.
Drive it and don't worry about it.
I’m right at 10,000 miles ,this truck is really nice .Cant day enough about the great power around town.Easily the best 1/2 ton diesel.
Well I finally did it. Took of the duratracs for some Cooper AT3 XLT to try and get some mileage back as well as no more road noise. On the way back to the office seemed to be a little better, around 10% it seems, closer to stock. Still running the 275/70/18c0114dee4d3d279e126a2b7115c67075.jpg
No alerts, no lights.
Regen is the process in when the diesel particulate filter "regenerates", aka cleans the soot the trap accumulates.  This typically occurs once per tank of fuel.  There are pressure sensors at the front and rear of the filter.  They monitor the differential in pressure before and after the trap to calculate the soot load in the DPF.  When it reaches an appropriate level, the truck will initiate a regen.  There is a hydrocarbon injector (7th fuel injector) that doses hydrocarbons (diesel fuel) to ignite the trap and start/maintain the regen process.  Temps typically get in the 1100-1300 degree F range during a regen if you monitor via an OBDII software such as BlueDriver.
The most common sight to see is a higher idle when in gear.  For example, on my 2016 Colorado diesel, it would idle about 700rpm normally, and during a regen would idle at 900-1000rpm.  This was noticeable on the tachometer, and was audible in that you could hear the idle was slightly elevated.  You may also notice a stronger odor when stopped at a light during a regen.  From my experience, its similar to the normal smell of these engines, but add in some old school diesel aroma, and it smells "hotter" as well.
Another very common telltale of a regen is your instant fuel economy.  For example, my Colorado.  At 65mph, it toggled between 30-34mpg.  During regen, it was almost always 19-22mpg on the live readout.
You can if you had to, shut off the truck during a regen.  If that were to occur, there will be a message in the DIC stating for you to drive the vehicle at XXmph to perform the regen.  If you are able at all over your time of owning it, pick up on when its doing a regen, driving through the whole thing ensures a proper burn of the DPF.
Have 2020 GMC Sierra crew cab 4x4, with the 3.0 liter and have had no problems, Bought it Oct. 2019 attached is the latest mileage from a 2 hour trip in New Hampshire up north driving 55 mph average over 40 mpg on this trip got a high of 42.4 as the best. Have just over 3500 miles on it.
I found this supplement in my warranty booklet, am I reading this right, our 3L Diesel’s get 5 year/ 160,000km (100,000mile) powertrain warranty instead of the typical 100km?
It's been that way with the big brother -- 5 yr, 100,000 mile / 160,000 km  powertrain.
Rest of truck same as the gasser.
Edited by redwngr
    Smitty462
    Smitty462
  • Who's Online   4 Members, 0 Anonymous, 579 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
