Anybody ever installed these?
Omarios
Hello all,
I’m kind of wondering, has anybody ever installed this DRL kit from Diode Dynamics? It basically lets you choose between amber and white LEDs. Yesterday I came across a 2016+ Silverado with amber LEDs at night and it was sick!! Might be looking to make something similar but I want to see more pictures of this kit installed and hear anything someone might have to say about the quality.
here’s a video:
I thought about doing it and Klearz the turn signals and using switchbacks. I just don't want to drop the money on it right now. I have 4 of their 6 inch light bars (3 mounted, going to relocate 1 and add the other next to it). Other than their review photos on their website, I haven't seen any other Silverados or Sierras with them.
I like the idea of all white (switching amber fog lens for clear and Klearing turns) but I also kind of dig the idea of having the amber running lights, amber turn signals (switchback sorta setup where they're on with running lights) and amber fogs.08fd7dfbc1922cb784e0dcdbfc3510d0.jpg
Sent from my SM-G965U using Tapatalk
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
