I chose to not go with the grille kit, I did not want to cut up the stock grille. I ordered the 20” rough country light bar and was very happy with the quality for $150. Installed it behind the grill and love the outcome.
What bracket did you use for this install. Looks good.
Sent from my SM-N960U1 using Tapatalk
On 10/8/2019 at 9:33 AM, CMillSilverado said:
...Baja D was willing to sell me just the mounts. I'll post up a review when I get them mounted up tomorrow.
https://www.bajadesigns.com/Products/Chevy-Silverado-2019-Fog-Pocket-Mount-Kits.asp
I've had thoughts of trying to design a mount just about like those to 3d print.  Temp might be an issue though.  Was thinking I'd wire up a relay off of the high beams so I wouldn't have to worry about adding an extra switch...
Mine run off the factory fog light wires with no issue and come on when the high beams are on with a jumper wire.
Well
I got mine installed. They look like they are from the factory the. Way they fit.
Took about 2 hours to knock out. It's crazy how simple it is to get the grill off of this truck. 10 push clips, 4 bolts, and it pops right off.
Need to wait until tonight to see how much light they put out. 90137b6277bf66e31071fbb168b460a4.jpg1caf9ff103faaf76df49e29a44472da7.jpg
  • Like 4
Alright, I know everyone wants to know what these lights put out.
Here is a photo of just the LEDs running with no other lights on.
You can see that the lights produce a flood pattern that fills in nicely. The spread is much taller than I expected.
There isn't much throw on these lights so don't get them for that.
They are stronger than the low beams but don't reach out far enough for high beam replacements.
I would have loved if this light was a combo pattern. Floods on the edges and throws down the middle.
Ooooh. Kinda what I’m looking for.
Picture with the lows on also?
Ok. Here are a couple of shots at an intersection
Lows Only
Lows and LEDs
  • Like 4
Lows Only
Lows and LEDs
Thanks for the pics. I hate to ask but any comparison to stock hi beam output as well?  That’s the big one for me.
Already ahead of you.
Another set of shots.
Lows only
High Beam Only
Lows and LEDs
High Beams and LEDs
In general. These lights are an excellent choice for fill light. Hits the edges really nice. You don't get a lot of throw with these to replace high beams, but you can see a bit further than the low beams only.
I would say these lights are kinda like a mid throw fill light.
Works well in findings critters that are trying to become hood ornaments at night.
Caught this guy coming up out of the ditch as I turned the corner. Took his sweet time getting across the road.
Lows only
High Beam Only
Lows and LEDs
High Beams and LEDs
Awesome information.  Thanks for taking the time to post these.  Truly appreciated!
Great pictures, how hard is it to wire up?
Also is it hard to cut out the grille?
Grill took me an hour to remove, get it taped up and cut out using a mini hacksaw and get the lights installed in the grill.
15 minutes to get the relay mounted to the firewall, and route and zip tie all of the cableling up so it looked nice and neat.
5 minutes to reinstall the grill
The hardest part of this job is getting the wiring thru the firewall. I used the plug in front of the door jam on the passenger side using a fish tape to thread it thru. Took me an hour to do that, then route the control switch over to the spot that I wanted it. I couldn't reach the firewall plug behind the battery without removing it. I wasn't in the mood to remove all of that stuff to get to it.
I had a wireless lighting controller as a backup just in case. Didn't need it after all and sent it back to Amazon.
One more question, in your pictures, are the fog lights off when you put the high beams on? Did you mod it so that the fog lights are always on?
Modded.
My fog lights are on automatically with the high beams.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
