I’m sorry I worded this poorly,
I installed the gm Cai MYSELF, then brought the truck over to the dealership for a RE-TUNE.
the dealership is trying to charge me for the re-tune
39 minutes ago, nino said:
This is what I’m saying, I installed it myself and brought to dealership for re-tune, should be covered right ?
Yes, as long as you have the code for them that came with the CAI,  They will use that to update the computer and charge GM.
I installed mine also.  I took the truck in yesterday.  Took the dealer about an hour because they were busy.  Showed them my paperwork from where I bought it and no charge, no problems.  The billing number they use is on your paperwork.  I really did not notice any improved throttle response but the idle is smoother.  FYI the speed limiter on the 6.2L is set at 112MPH, have to find a way around that.  No tuners out there yet.
I purchased mine from a re-seller I guess.. there's no labor code on any of my paperwork..
how much are  y'all being charged?
my technician buddy doesn't live in my state..
Edited by rbrjr1
Please purchase a custom driveshaft first. They are the weak-link and the reason for the speed limiter, that and OEM tire ratings. Many K2 guys found this out the hard way.
Interesting, I did not know that and did not have any issues with the aluminum driveshaft on my 2015 K2.  Most of the speed limiter are set due to tire speed rating plus a truck really has no business going that fast.  With that said, it was pulling real hard until the rev limiter cut the engine down. I love this new 6.2L engine.
  • 1 year later...
We’re you able to get it done I’m about to do the same
You speed is limited to the tires that shipped with the truck.  My 6.2 is limited to 98 (TB with duratracs).
Right, but they must apply some unknown GM formula also, to give themselves a big pad on prospective warranty claims.  My last new Z71 was governed to 96mph which was 86% of the capability of it's "S" (112mph) rated Dueler A/T's.
If you hit the speed limiter at wide open throttle it'll throw you forward in your seat because of the sudden stop in acceleration. Been there, done that.
I don't know of anything other than the tire rating.  The duratracs (according to goodyear website) that come on the TB/AT4 have a speed rating of 99.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,264 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
