2 hours ago, 19ShadowCustom said:
nice truck, but this is T1 forum.
Ok can you clarify T1?  Kind of new to the Chev/my world
There are several names for this color on lots of different vehicles.  Regardless the color code if GJI.  I have searched high and low to find a powder coat that would match but to no avail.  I really want to color my chrome bumpers.  The local bedliner shop that does kevlar spray said they could color match kevlar.  Its kinda cool, and would be tough as nails on a bumper.  Its a little rougher than I like though.
Refers to the internal designation for the new generation/new body style that started in 2019.  There were also 2019 double cabs in the old body style during the change-over process.
Your 2017 is a K2
Before that there was GMT900,
before that the GMT800 (which was the first ones to use the hydroformed front rails in the frame)
Before that, different frame supplier and the 400 series....
Fwiw, GM refers to paint colours by the order code. (RPO code)
Sometimes chev and gmc (and the other divisions) will use the same paint colour, and same rpo code, but label it with a different name.
It's common for the shade of the colour to change every few years, and some colours are one year or part year colours.
In any case, correct colour matching is done by the RPO code (order code). Pictures often
GMC calls   GJI  Dark Sky Metallic
Chev calls GJI  Shadow Gray Metallic
So this thread could have been called Dark Sky Metallic / Shadow Gray Metallic
GJI wasn't available on 2017.
Is yours 'Graphite Metallic'?
If so, it's RPO code is GPA.  (GMC called GPA Dark Slate Metallic)
It's no longer available.
The 2017 should have the label in the glove box that lists the RPO codes.  They have moved the info to a QR code on the door post --- that can be read using a phone app.  Of course any dealer (or gm chat / social media) can also run the vin and get a list of 'as built' codes.
  • 8 months later...
My dark sky Denali. First saw it on the lot the way the salesman said it was blue and the way the sun hit the color I almost walked back in and said there’s a gray one out there but I don’t see a blue one
9 minutes ago, Tjeli said:
Damn, forgot how good looking these are, I need to go out and wash mine so it looks this good again!
First post, 2020 LT Trail Boss is the best color SGM.
S/F
Adam
Edited by ACM0302
Misspelling
Not the best picture, but I found some AT4 wheels local and swapped out my RST 20s. Much better, but the Duratrac tires are going to have to go.
    • I'm the original poster of this thread; I'm 85,000 miles now with no transmission issues after they did the fluid change without filter at 45,000.  I plan on a fluid change AND filter in another 5,000 miles and agree with you on staying to witness what happens if possible.  Ideally I would have done the filter at 45,000 too, but my original dealer was incompetent.  I've since moved on and get service done by another more reputable dealer, so I'm hopeful they follow the correct procedure at 90,000.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
