Just like the topic says. Like to see how some higher mileage t1's are doing. I know there is a topic for high mileage 2019's but I would like to extend that to 2020's.
My 2020  AT4 only has 1500 miles, coming from a 2009 (relatively) trouble free 160,000 mile Tacoma (which I purchased new) I am real curious how the T1's hold up.
almost at 12k
3 dealership visits for my engine knocking noise. about 4 weeks total out of service.. still knocks. sounds like its going blow up on cold start.
1 dealer visit to have the frame coating redone because the frame already had rust spots after 900 miles
1 dealer visit for flashing check engine light. 1 week out of service.
Going back in tomorrow because my brakes randomly didn't work last night backing out of a parking spot at the grocery store.
Edited by ct_corey
spelling
  • Sad 1
Saw one on Autotrader with 45,000 on it. I think that's the highest mile T1 I've come across. Mine is at 7k.
Mine has 14K miles but outside of having my passenger mirror replaced twice I haven’t had any issues. I don’t understand my front brakes at 14%... It’s been stuck on 14% since 12K miles... I mentioned to my service advisor when I had my truck serviced at 12K miles and he said it wasn’t an issue. Meaning my brakes were fine... Still doesn’t make sense how low it is reading but I can ignore that for now...
There’s a TSB for this. Find a better service advisor.
Glad people are chiming on with no problems as well as people that have issues. My FIL said every GMC he had, all his issues/problems came in the first 10,000 miles and trouble free after that....
2019 TB LT. 25k and only issue was the oil cooler line at 22k. Dealer extended the warranty on the engine and no further issues. Build date of 12/15/19 and picked up 1/12/19.
13K and my old issue is the old lady that missed her brake pedal coming in behind me at a traffic light and crushed my bumper and beside... probably saved her from getting seriously t-boned though.
Did the motor get starved of oil while you were driving?
I do not think so, I got off the road immediately but I figure better safe than sorry and the dealer was willing to submit the claim to GM (after multiple follow up calls). I plan to keep the truck for 5-7 years so it was important to me.
Did you mean build 12/15/18?
    Matt Parker
    Matt Parker
  • Who's Online   2 Members, 0 Anonymous, 819 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
