I bit the bullet and bought the factory GM camera. I did the install today using the factory furion mount. Popped the hole behind the mount into the rear top bunk, then into the shower wall and fished up the length of the trailer. I coiled the excess wire up and secured in the underbelly. I will say the camera is crystal clear and I can’t wait to use it on my trip. I opted for the plan model camera that doesn’t have the invisible view. I highly recommend it. 8A6B994A-DBFF-480F-B0A5-863011A54ABF.jpeg.2e3cd39436351d0f2f025885d9b5cf2f.jpeg
Great job, you’re going to love it. I agree that the image is crystal clear.
I like the idea of going through the hole already there from the Furrion camera.
They need a wireless version that connects to the infotainment system. I've tried a few times and my 5er is just too long and I keep snatching it out of the end. I went back to my Furrion wireless observation camera. On the plus side, I can put the monitor inside and watch what's going on. LOL!
I have a 2020 GMC 3500 Denali and purchased the trailer camera for my RV.  does anyone know where i can get a 10' extension cable for the camera, as mine is a little short.
I'll send you a DM - I have a 10' one I ordered but didn't end up needing.
 Without having read all 10 pages...is there an aftermarket camera available that will plug directly to the system or is GM the only source thus far?
I'm really not too concerned with the invisible view. I just want to see behind my camper.
While driving, if you switch to the rear camera view will it stay on your display or is it only on the 10sec timer like the other camera views?  I'd love to have that view visible constantly while towing like a rear view mirror. Wonder if anyone has wired their trailer camera to the tailgate camera so it shows in the electronic rear view mirror?
Great thread everyone. I've learned more here that I could glean from Chevrolet sales & tech materials. I have just ordered a 2022 Chevy 3500HD DRW Double cab longbed LT to haul a large-ish slide-in camper. I spec'd out the UVN Bed View Camera so the truck will come with the two camera jacks on the rear bumper.
It sounds like the Auxiliary Trailer Camera (Part # 85004154) will be the right choice to mount on the back of the slide-in camper and I hope the system will still work once the tailgate is removed. Has anyone tried this, with or without a truck camper? I don't expect or need the invisible view (as cool as it is!) but would really like a high quality rear camera view integrated with the truck infotainment when the camper is loaded. In my use scenario, might the camera need to be plugged into the "inside view" jack?
Having a second screen for a third party camera system is a really weak second choice when Chevrolet built this great system. Thanks for all the great information...ned.
On 7/27/2021 at 9:43 PM, ShogunKC said:
could you tell me where you bought the 10 foot extension cable for the cameras system from ? thank you
52 minutes ago, rock crawler said:
You can purchase the cables online through Pasternack (https://www.pasternack.com/). The SKU for the 10' cable is
PE3W08444-120. The last 3 digits represent the length of the cable in inches, so if you need a 20' cable, the SKU would be PE3W08444-240.
I bought one of those cables. The connectors are smaller than the end of the factory cable that is attached to the camera. Did you need to modify your camera cable to accept the much smaller connector? How about plugging the much smaller end of the cable from pasternack into the back of the truck? How did you use the cable?
Is it:
Truck Bumper Connector <> Extension Cable <> Factory Standard Camera Cable <> Camera?
OR
Truck Bumper Connector <> Factory Standard Camera Cable <> Extension Cable <> Camera?
OR
Something else?
I am looking to extend my camera cable by about 10 feet and am not seeing how the pasternack cable will fit the connector on the bumper and/or the connector on the cable. Can you share pictures?
Many thanks for your help! Really appreciate it.
Edited by cavenerd
On 2/20/2020 at 6:45 PM, XY74 said:
The camera is marked "top" and the cord exits the camera body going up no matter how you position the bracket.  If you turn the camera over, the image would be reversed.  The loop isn't ideal, but it is necessary if you are going underneath.  I'm debating painting the cable the same color as the trailer just to make it stick out less.
Have a 2020 Keystone Montana 3741FK (40’ 5th wheel) and read through this whole thread and many others last year. Had issues with the wireless camera and decided to buy the GM camera. Mounted it high and ran the cable down the ladder and underneath in pvc conduit. Fished through to the hitch near the 7 pin cable. Want to move the camera jack from the bumper to the bed but haven’t yet because of a problem. Everything works great (we do get a little fish eye) until it doesn’t. After 3-4 hours of towing the video display goes haywire. Have had it to the dealership three times. 1st time did some type of reprogramming - no change. 2nd time replaced video processing module - no change. 3rd time they tried to recreate problem and couldn’t - now they want my trailer along with my truck.  Wondering if anyone has seen or heard of a similar issue.
Similar, but not on the Chevy system.  A few years back we used PVC pipe to run the video cable through.  The area was really windy, and we didn't want the cable damaged.  Problem was, the wind generated static electricity in the PVC, it would build up and create weird video issues.  We ended up grounding the PVC to stop the issue.
Might be worth trying to ground the PVC to the frame of the 5th wheel, if it isn't already.  Probably a few metal clamps along the pipe would do.  Cheap thing to try.
Good luck, and happy trails. :cheers:
"underneath in pvc conduit. "
wind will cause static build  up on PVC when driving...
you may get lucky grounding the PVC...but how I do not know
else run a new cable to verify
This is my first post here since I just replaced my Ram with a 2022 Silverado 1500LTD LTZ.  I have the surround vision system and want to add the rear trailer camera to get rid of the extra monitor I used with my 30' travel trailer.
I just purchased and received the trailer camera (PN 85004154) from Shop Chevy Parts.  I plugged it in but the truck is not detecting it.  Does a trailer have to be connected for it to work?  My camper is in storage and I have not been able to get over there to check out the full trailer setup.  I want to make sure it works before I install anything.  I also need to get it over to a tire shop to have the included tire pressure sensors installed in my camper.
One other thought I just had...  I do not have the tow mirrors.  Will the system still work well (including invisible trailer mode) with the standard mirrors and an 8' wide camper?  I'm not sure that the cameras on the regular mirrors I have are out far enough to see all the way down the trailer side.
Thanks in advance for any input.
    Clark_Elite
    Clark_Elite
  • Who's Online   6 Members, 0 Anonymous, 476 Guests (See full list)
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
