15k Service turns into an adventure
Ok, think final update on this but wanted to close the loop.  I took the 2020 Silverado High Country Diesel.  End result, I was able to get in the truck for exactly what I owed on my 19, no out of pocket costs and actually received 1800 back in cash.  Also secured a full bumper to bumper warranty for 7 years covering everything and I mean everything.  Also got credit for next 2 oil changes and the trailer camera (lets you see through the trailer).  Been driving the diesel for a few days now and there was a learning curve but overall, the MPG is outstanding.  I appreciate everyone's input and recommendations while I was navigating this process.
  • Replies 136
Great!
GM does the right thing sometimes.
Congrats Harry, hope your new rig is trouble free for you, and good on your dealer for handling this right and not prolonging it.
So... they ate about 15K.... Diesel for gas, 20 for a 19 plus, plus. I’m pretty open minded, but. Their insurance probably covered the damage to your truck. I can see a trade for same year equal equipment and extended warranty for extended time. And free service, if you dare. That’s just too much.
Sweet new ride. Congrats Harry. To bad you had to go through that in the first place.
Damn, that's a hell of a story, but glad that the dealer stepped up in the end and took care of you!
No sounds just about right to me, really why come in this thread and give an opinion like this? What good is telling a person here that they should of not received this kind of satisfaction going to do, or maybe i'm reading your post wrong or at least i hope.
When something’s to good to be true, well you know the rest
On 2/6/2020 at 8:37 AM, diyer2 said:
Great!
I think GM had nothing to do with this since the Dealer screwed up the truck.
Good point!
The issue I’m having is from start to finish it was less than 2 weeks. Broke the truck ordered a new engine, fixed the truck then took it back and replaced the truck with a 2020? all in two weeks not a chance that could happen so quickly. More to this story. Chevrolet dealers just don’t bend over that easily.
So your saying the OP is a liar?? Really trying to understand what seems like anger or jealousy that he got a replacement for the troubles his dealer had put him through. Did you happen to read all of this post and see that his dealer initially committed fraud with GM by submitting a false warranty claim for the engine they blew by running it without oil? Pretty easy to see that the GM of this dealer knew taking care of this regardless of out of pocket expenses would be smart on their part IMO!
I’m saying it doesn’t add up at all. Liar possibly. It’s not the whole truth for sure. The Dealer was on the hook for an engine no more. If the dealer filed falsified $7K in warranty claims they could lose the franchise with Chevrolet.  $20K loss on the trade out minimum plus $7k loss on the engine equals a $27K oil change for the dealer? I don’t even think the dealers insurance company would total a $60K truck out for a bad engine on a 2019 vehicle if it came to that.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
