Wash and waxed,  floor liners, bed matt.
so wish i would have found one with cab lights. nice truck
More pieces to the puzzle arrived! Woohoo! I’ve slowly been chipping away at my custom air compressor install, re made my own harnesses, completely took apart the supplied harnesses, its been a fun project.
One of my last steps is to install the air lines, I still need to buy a short and long stainless steel air line but I needed my air bags to arrive first so I could mount them up and know exactly how long I needed.
Air Lift 5000 ultimate bags arrived tonight and I partially assembled them, if it’s not raining tomorrow I’ll throw them in the truck. Never had air bags before, or an onboard air compressor, super stoked!
ef6d91ca7552c497e60abb3cf824227f.plist
  • Like 4
I added " Chevrolet " to back tailgate in which I already had well before I bought the truck to put on my 1500.....it will remain stock for awhile....bedliner next week but that's a given, coilover suspension is first on list....
Was this the GM black sticker? If so I’m wanting to do that too!
Nah I had sticker on 1500....this is domed black letters...looks a bit more factory imo, though for some reason " ET" looks crooked in pic.....she is dirty girl right now, needs a bath
Edited by Dunn
Finished this off this weekend, sounds great:
Also upgraded the front tweeters:
I also installed these a few weeks back:
i put amp steps on mine sunday as well. how do you like the sub?
The amp steps are so great, best mod to the truck no question.
The sub is good. I got the kit with an amp for the other 6 speakers too. The value to me was a clean, simple install without mortgaging the house. I priced out my dream JL Audio system and it’s somewhere near $6k - not realistic for me. This is a fraction of that, and for the price I’m happy. Not that $999 on ShopChevyParts is cheap in times like this, but I think it all works well.
I listen to everything, old rock, classic rock, old rap, country, you name it and it pretty much does the job.
The 2.75” upgrade just about needed the whole dash taken out, but an afternoon and it was done. I also have some door speakers ready to go, but that’s another afternoon. Half the pleasure is taking my time and installing everything right, not tearing up the rig.
Chrome delete process, to blackout the toe hooks or not? New KMC wheels. Bed cover on its way. Amp power steps are next.
Edited by KuiMonster
Your truck looks great with the black trim that you're adding!
I had my red hooks re-powdered black and it made a huge difference.
Yours would look better black IMHO.  To me, they look like nipple rings on your truck!
Edited by cdh7917
2020 GMC Sierra Denali Ultimate 2500 HD with a Turbo Diesel, 5 inch Zone lift, Nitto 37" Terrain Grapplers, Amp XL powered boards, color matched fender Flair's, rear LED and Kicker tailgate speaker package, 50% ceramic 3M tint on the windshield and rear, 20% on the front, Horn Blasters 2485 nightmare dual tank kit with spare tire delete and 8" drop hitch.
Try saying that 10 times fast lol.
Phase 2 is a front bumper swap (painted to match) light bar, 12,500 lb wench, roll bar, LED pods.
I am beyond blessed, and thankful to God every day!6791074986232b38acf5610fb36a96ea.jpg2e22248637369ab44d63fa60d7b52121.jpg6b56e40d8506baf01b8a2309c9f4608e.jpg9409cc65388e3a3825a27b15927bee51.jpg
Sent from my SM-G988U1 using Tapatalk
  • Like 7
Did you add the rear light bar or have the dealer do it?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
