Hi, I'm new to the forum, but not new to Chevy trucks. I just traded in my 03 Avalanche for a 20 Trail Boss. I love the truck, but it didn't include whatever package that added steering wheel controls... It has cruise control on the wheel, and that's it. My question is; is it possible to add stock OEM control features to the steering wheel? the cruise is on the left and there's a blank on the right. What I'd like to add is controls for the stereo. I have the infotainment package, and it would be nice to control it conveniently. Why they didn't add this to the package, I'll never understand.. Any help is greatly appreciated.
You should be able to use those arrows to navigate to the "Music" display centered on your dashboard if you go two to the right from the default display. You can select your favorites and change stations from there. It's not perfect, but it's something.
If it's a custom trail boss, there is no option to get stereo steering wheel controls.  I don't think there is a easy way to add it either, it would require a dealership visit to reprogram the BCM
Does it have the buttons on the back of the steering wheel for volume (rhs) and to change station (lhs)?
yeah there is a few threads on this, I dont think anyone found a solution......basically the controls on right side of wheel control the cluster and phone.....custom has different cluster and uses an old school dial....back of steering wheel is for volume and changing radio presets
I too would love to add the buttons on the steering wheel for the audio system control.  I use Android Auto a lot with Waze for navigation.  But, if I'm listening to the radio, there's seemingly no way to change the station to a different station, other than to hit the home button, then audio on the screen.  Quite annoying.  I don't mind reaching for the volume on the dash, but being able to scroll to the next preset would be awesome.
I wish I had a schematic for the truck, but from earlier GM vehicles that I've worked with, the volume controls are all on the CAN bus.  It appears that the cruise control is also on the same bus.  From an initial search that I did, it looks like the steering wheel clock spring only changes if the steering wheel is heated, so the CAN bus should be there  in our wheel.
If I try, I'd probably just get these two parts:
The steering wheel switch (13531288) :  https://www.gmpartsgarage.com/oem-parts/gm-audio-switch-13531288
The different wire harness (84449305) https://www.gmpartsgarage.com/oem-parts/gm-harness-84449305
(I personally don't care about the switches on the back of the wheel.)
With any luck, the CAN IDs sent from those buttons would be understood from the audio system.
Otherwise, I doubt that there would be a way to make it work.  I believe that all of the trucks that have the steering wheel controls have a different sound system.  I have no idea if BCM programming could enable the switches to work without the other audio system, but I doubt it.  Hopefully our audio system will just understand the IDs being sent.
Who wants to be the guinea pig?  :)
Edited by Railroad_Jim
typos
  • 4 months later...
Has anyone tried this yet?  I have a 2020 2500HD WT that I want to do this too.  I have order the steering wheel harness, radio switch and control.  Will be here Monday, I assume it is doable.  I wanted remote start, so I ordered the kit from GM Parts Direct and the only thing that showed up was 2 fobs and an authorization code.  Says you just need locksmith to reprogram (Im scheduled so we'll see)
I Have swapped out my Steering wheel with a Leather wheel which has the Buttons on the right. I also have swapped the Speedometer with a High Country one. It does not work . The Cruse control buttons work however, I have to reinstall my old speedometer because I am not able to toggle thru the menus. Its a bummer because it makes a huge difference in the interior.
Edited by Zelas
Grammer
Have you contacted White's or anybody to see if it could be programmed?
Yea. White did my speedometer program. He told me to email the harnessdr.com guy. He said he has no info yet. Only for older truck.
Ok, thanks. Been contemplating a dash replacement on my custom. But not being able to scroll the menu is holding me back.
Yea. I would hold off. It’s an expensive lesson.
Not that it would matter too much but did you also swap the steering wheel harness plug when you did the wheel swap? Why not just keep the high country cluster, not much you "need" in the menus for the cluster is there?
It’s been in there for 2 months. Yes the harness was swapped. I think the clock spring might be different. If the cluster was not stuck on gas screen it would be great. Also can’t reprogram tire pressure sensors
Did these parts do the trick?
    250.3k
    Tiffanyrose
    Tiffanyrose
  • Who's Online   2 Members, 0 Anonymous, 1,008 Guests (See full list)
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
