The Dexos-D 0W20 and the PF 66 oil filters are VERY HARD to locate. Before making an oil and filter change at the dealer call the parts department FIRST. Most dealers do not stock the oil or the filters and have to order it in for your oil change so make sure you call the parts department ahead before making an appointment for an oil change. Hopefully this will change when more 3.0L hit the streets but not so much right now.
Edited by ILSilverado
Could you post the Delco Part Number so that other forum users can cross-reference the Delco # with a  Fram, Baldwin, Donaldson etc # if they find themselves in your position with parts unavailable at the dealer, please?
EDIT: Nevermind, I see you posted PF66. I tried to cross reference it with no luck. Must be a new design.
Edited by L86 All Terrain
Wix WL10351.  Also, Summit Racing online lists AC Delco PF-66 oil filters for sale.
AC Delco Dexos D oil from GM Dealer or Mobil1 ESP (Dexos D rated) oil from Mobil dealer.
Edited by MaverickZ71
The Delco part number for the filter is, #55495105 /PF66  The Oíl is Dexos/D 0w20 and I’m told it’s only sold under the Delco and Mobil-1 labels as of now. In fact it’s sourced under the Delco brand by Mobil.
7 hours ago, Gswartz said:
How often do they want the oil changed in the 3.0?
Every 7500 miles. I’m changing mine at 1500 for the first time then I will go to a 5000 mile schedule after that.
ILSilverado
I'm not telling you what to do. Just food for thought.
This is factory oil at 700 miles out of a new gas GDI turbo motor.
4 hours ago, diyer2 said:
ILSilverado
Thats quite normal looking. This is why Diesels use a special oil formulation and doesn’t  use the same Mobil1 that’s used in gas engine’s.
The dmaxes have an OLM, just as the gassers do.
3.0 supplement says:
The engine oil life system calculates engine oil life based on vehicle use
and displays the CHANGE ENGINE OIL SOON message when it is time
to change the engine oil and filter.
The oil life system should be reset to 100% only following an oil
change. See “Engine Oil Life System” in the owner’s manual.
OM of course, says
This vehicle has a computer system that indicates when to change the engine oil and filter.
This is based on a combination of factors which include engine revolutions, engine temperature, and miles driven.
Based on driving conditions, the mileage at which an oil change is indicated can vary considerably.
For the oil life system to work properly, the system must be reset every time the oil is changed.
This is my schedule for oil changes, 1st 1000 miles 2nd 5000 3rd thru 25 OLM
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
