19 hours ago, newdude said:
Well, bigger doesn't necessarily = safer on a tire.  That comes down to proper air pressure, tread design (all season vs. all terrain), tire contact to the road, etc.  Going too big on a stock wheel can put the tire out of its rim working zone which can compromise how the tire sits on the wheel and its tread contact.
Informational bits aside, if you are looking at the Michelin Defender LTX MS, in both stock 265/65R18 and 275/65R18, they are rated for wheel working width of 7.5"-9.5" wide wheels.  Tire companies typically measure the happy spot right in the middle, and Michelin has the section widths (side wall to side wall of the tire) measured based on an 8 inch wide wheel (stock wheels are 8.5").  So, long and short, a 275/65R18 is beyond acceptable to upsize on a stock wheel and would be safe to do so.
As for perfromance, you may see a bit more on the handling side (wider tread) and you might get some slight tramlining (feels like you are on trolley rails) on pavement and concrete (my stock size Continental Terrain Contact HT do this on concrete).  Otherwise, I'd expect them to perform about equal to the stock size tires, but your judgement once you monted that size will be the true determination for your ROI on them.
this is great insight, thank you!
21 hours ago, Grumpy Bear said:
You've watched tire reviews from experts like Tire Rack? You may have noticed that much of what your asking is subjective. Even multiple testers don't always agree so they grade by general consensus. Things like steering 'feel' and tire "boom'. Turn in response and vehicle rotation through a turn are considered.
Consumer reviews are individually more pointed but shotgun like in collective breadth.
However the Pro's do some objective testing as well. Stopping distances, skid pad and slalom times. I find it interesting that within in a category of tire the results while different are also quite small but safety is a matter of inches and feet and one tire of the three generally tested in a group will consistently have some edge no matter how small. Also interesting to me is there are tires whose objective test are a hair lower but have a 'feel' that inspires confidence so that a novice driver can actually get more from it that the uneasy feel of the higher ranked tire will let their internal warning lights obtain.
They never test between groups but objective results are derived at the same test parameters. So printing off a sheet for each tire and then comparing only the subjective elements will render some usable results.
Some things are just obvious. Some tire types and patterns are just inherently more noisy. Some like white lettering, some don't. Some prefer a treads look to another.
A tip or two on consumer reviews. At least at Tire Rack they break the reviews into mileage groups. I look at reviews for a tire that have multiple reviews from drivers who exceed the warranty miles and drive some vehicle close to what I what to put them on. A review over 1 K miles doesn't tell me anything useful unless it is in comparison to the 70 K reviews. What do you think? If 10 guys get 70 K and are happy and 10 whine that they can't get 25 K before it wears out do you think it's the tire or the driver or the vehicles state of maintenance? Is it the tires fault?
Tire threads go on for pages and pages and often end in heated exchanges and nothing is accomplished. They are going on your truck (or your wife's).
All tires have this constant. They work best and last the longest on vehicles that are well aligned with tires properly inflated, rotated and occasionally balanced and driven by a rational adult. That last element can be hard to find :lol:.
I hope I said something useful in the 20 minutes to took to think and type this. ? Now, I have grass to mow. Later and have a nice morning, eh?
thanks for your response...and although i agree with most/all of what you said, I would be comparing the same tire, same tread, just a slightly larger version...so you are right...people get passionate about their tires (for some reason, im not really sure)...and everyone has an opinion...my opinion is i know the Michelin Defender is an ugly tire, but it just performs as good if not better than any other tire in that category...so i am getting that for my wife's vehicle because she doesnt care about looks or anything else...i am just comparing stock size to a slightly larger version...
Then it will be larger and heavier and take a bit longer to stop and a bit more fuel to wind up. For the same brand and a badge could be as little as a pound.
I get it. I have Defenders on one of my cars and it's been a great tire. Fact is I've had few bad tires even among several brands. I've had different but not bad. Lifetime maybe one set that wouldn't balance and one set of Firestone 500's in the 70's that were recalled for defective belts. I already had them 10 K past the warranty point and they were working fine, wearing well and looking good and Firestone just bough me five new tires. COOL! :)
I think one thing people looking a tire test forget is testers put those tires on their limits. Actually they go beyond their limits or they wouldn't know what the limit was. We just don't drive like that as a general rule. The other thing is the vehicle the tire is mounted to has a huge effect on things like skid pad numbers and braking distance. They are meant to ferret out the differences in the tires in a control (sort of) setting.
Anyway, wishing you well and enjoy the ride. :driving:
From the specs on the Tire Rack website, the difference between the 2 sizes of Michelin Defender LTX M/S highway all-season tire listed above is 275/65R18 costs $34 more than 265/65R18, has 155 lb more weight-carrying capacity, weighs 2 lbs more, is a hardly noticeable 0.7 inch wider at the tread, is 0.6 inches taller overall, and turns 648 revs per mile as compared to 659 for the 'smaller' tire.
Executive summary:  For the $136+tax extra that the 'taller' tires cost, you may have a very slightly softer ride over bumps, your steering feel at turn-in will be a little sloppier, and your acceleration, braking, handling, and fuel mileage will be a tad worse with the taller tire.  And your speedometer/odometer will be understated by 1.7% with the taller tire.  I'd go with the 'smaller' tire unless you just really need that additional 620 lbs of payload capacity, and then I'd still wonder if your stock axle and suspension was up to the task of the additional load.  But at the end of the day, it's your vehicle and your decision.  Happy motoring.
Edited by MaverickZ71
Personal story along this line. My 255R70/17 Bridgestone H/T are up for replacement. I've oped for a Perilli Scorpion HT in P265R65/17. One pound lighter, a half inch shorter and a half inch wider. That translated into a slightly less (2%) mass equivelant but a 5% lower inertia moment.
Inertia moment?  You mean like getting out of bed early on a Saturday?  :D
  • Haha 1
Exactly like that!
 :crackup:
Lots of good advice. While I would say looks are the biggest return, a lot of ROI depends on your current tire as well. My burb came with 265/65/18R112 Michelin energy savers (actually not bad for DFW hwy commute @ 85mph); going to Defenders in the 275/65/18R116 size would net me almost 1200lbs more load capacity at same speed rating, and still be a comfortable P metric tire. This is better for all 'truckery' be it hauling, towing, or off roading, and just makes for a tougher tire. I think I can get another year out of the stockers, but if a good sale comes up - Im jumping on the 275 defenders...
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
