I just watched a couple of YouTubes on these. There are a couple different brands but one thing that stuck out was they said that if you remote start your vehicle it might disconnect.  I am very interested in this so I can add in the wireless charging and not have any plugs showing.
I screwed around with mine again today, still no luck.
I got my Carplay2air a few weeks ago and has been flawless in my 2020. I didn’t update it to the newest version as it works perfect and don’t want to chance the update screwing it up. It connects every time but takes about 10-20 seconds
I'm getting a replacement for mine, no lights on it.  Hopefully when I get the new one, it will finally work as expected.
Check the USB plug you are using, plug your phone directly into it and verify CarPlay works from that location.  Some USB plugs do not go directly to radio
Interesting, tempted to buy this for my brand new 2020 that somehow lacks wireless CarPlay but has a charger haha
Any tips to getting it to work? They told me to make sure my phone and truck isn’t connected to any WiFi’s and a few other steps but nothing works, I can see it’s doing something but not what it’s supposed to do for sure.
Hmm the only thing I did was I NEVER updated. So right out of the box this is what I did I started my truck went into the Bluetooth settings to forget my phone. Shut the truck off then started again and plugged the dongle into the usb inside my center console. Then searched for Bluetooth on my phone and connected to the dongle and waited a little while for it to connect then made sure it worked. Then searched for updates to see if it was the latest version it isn’t so I NEVER updates as I wasn’t sure if it’s the new update messing other people’s dongle from working.
Edited by mx_master
Got mine- usually works. I did update mine. My doesn’t always connect but when it does it works pretty good.
Yeah mine is still pretty new so far out of 30-40 times I jumped in the truck to go for a drive it has connected every time. I don’t think I’ll do any updates unless it stops working. I have heard of people’s going to crap after a month or two so time will tell.
Edited by mx_master
Mines new as well- mine will say connect a compatible phone. Sometimes it will register when I start driving. Mine usually takes 2-3 minutes after starting before it’s up and going. It’s a decent piece. Hoping that 2021 GM option for the wireless CarPlay will be able to be retrofitted into my 20’.
Yeah mine has done that a few times as well but will always connect. Yep I’m also waiting for the 2021 retro idea I looked that up first to see if the new 2021Tahoe would work but no one has done it yet so I’ll go with this dongle for now till we can retro fit the 2021 modules in.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
