Currently working on a 6.0L V8 (2000 LQ9 I believe) and cannot seem to locate the PCV valve and hose (see image for reference).
 I was under the impression that they weren’t integrated into the valve cover until around 2005. The body of this truck is a 2000 Sierra 1500 but the engine was replaced from the 4.8 to the 6.0 at some point so I’m guessing for a lot of the component locations.
First time poster, any helps appreciated.
Edited by CremeSierra
It’s right underneath the plate that holds the cable to the throttle body. You can see it in the picture it’s halfway underneath in the front on the intake manifold. It has a small 2” long hose attached to it, follow the plastic tube that’s attached to it. It goes to the left side valve cover where the Pcv is.
Thanks for your help man, I've attached an edited photo of the engine bay. Is that the particular hose you were talking about? I've watched nearly every video online, and I don't seem to have the matching "thicker hose" that enters the drivers side valve cover.
2 minutes ago, Silverado/Sierra guy said:
It’s above the one you highlighted
Oh I see, the cable directly up from the one highlighted in the rectangle? Has a black 90-degree fixing just under the plate you described?
1 minute ago, Silverado/Sierra guy said:
Yes, that’s the one. You follow it to the valve cover and the pcv should be there. I have 2001 Silverado, it’s the same thing.
You're a legend. Thanks again, will finish that off tomorrow!
  • 2 years later...
What is the plastic bit called that comes out of the top of the engine ???? it broke off of the actual hose that connects to the pcv i dont know what that part is called i have the valve but i cant replace it because the thing under the plate that has 3 bolts broke
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
