Currently working on a 6.0L V8 (2000 LQ9 I believe) and cannot seem to locate the PCV valve and hose (see image for reference).
 I was under the impression that they weren’t integrated into the valve cover until around 2005. The body of this truck is a 2000 Sierra 1500 but the engine was replaced from the 4.8 to the 6.0 at some point so I’m guessing for a lot of the component locations.
First time poster, any helps appreciated.
Edited by CremeSierra
It’s right underneath the plate that holds the cable to the throttle body. You can see it in the picture it’s halfway underneath in the front on the intake manifold. It has a small 2” long hose attached to it, follow the plastic tube that’s attached to it. It goes to the left side valve cover where the Pcv is.
Thanks for your help man, I've attached an edited photo of the engine bay. Is that the particular hose you were talking about? I've watched nearly every video online, and I don't seem to have the matching "thicker hose" that enters the drivers side valve cover.
2 minutes ago, Silverado/Sierra guy said:
It’s above the one you highlighted
Oh I see, the cable directly up from the one highlighted in the rectangle? Has a black 90-degree fixing just under the plate you described?
1 minute ago, Silverado/Sierra guy said:
Yes, that’s the one. You follow it to the valve cover and the pcv should be there. I have 2001 Silverado, it’s the same thing.
You're a legend. Thanks again, will finish that off tomorrow!
  • 2 years later...
What is the plastic bit called that comes out of the top of the engine ???? it broke off of the actual hose that connects to the pcv i dont know what that part is called i have the valve but i cant replace it because the thing under the plate that has 3 bolts broke
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems.   True story. One winter day no long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses more gas. She finally got unstuck spinning in 2wd.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
