Morning folks,
I am considering on installing a hood deflector on my truck. I'm looking for suggestions.... what are you folks using?
My 2020 Trail Boss has the factory GM hood deflector installed.  I'm not really a fan.  I don't care for the spring clips that hold it on.  I am ordering an AVS Aeroskin II.  I have had the original Aeroskin on the three previous trucks and I love them.
I have the AVS aeroskin 2 on my high country. I love it. I picked mine up at autoanything.com.  One year price match. My truck is black and you don't even notice it's on there until you come up to it. I would recommend having another set of hands if you are novice on putting these on. Gotta get them aligned correctly or it won't look right.
14 hours ago, Kchampagne said:
I have the Aeroskin Lightshield.  I like it.
That's a very unique color. Can't say that I have ever seen it. Would love to see a few more pics on it. Love the blacked out GMC logo.   I have a lot of that bronze look on my high country and it is really growing on me, I think this color would definitely do the same. NICE TRUCK.
Thank you!  I wanted a color that was a little more unique. I love it!!!  The GMC color is deep mahogony metallic and Chevy is havana brown. Here are a few more pics after my ceramic coating over the weekend.
Installed stampede's vigilante deflector. Did a how to write up here in the forum as the install instructions are kinda poor. I just don't like the idea of taping things to my truck It uses 2 clips that are clipped to hood but 3m rubberized "tape" protects it. The "tape" is like the wraps that are used now a days. No adhesive.
I also have the AVS Aeroskin II realy like the installation, no clips 3M tape.
I went with Weathertech. I liked the AVS and ordered 3 different ones and all 3 came scratched up pretty bad. If it wasn't for that I would have just stayed with AVS
If anyone is interested in an AVS Aeroskin 2, they are on sale now at autoanything.com for $55. 1 year price match. Just got back $9 from them when I ordered mine a month ago.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
