I really like how my 6.2 Max Tow 2020 Silverado Tows, plenty of power and handles pretty good.  However my big disappointment is in how much it squats with my 8000lb travel trailer is hooked up.  I have an Equalizer hitch for it that is supposed to help with weight distribution, and i thought i was paying for the heavy duty leaf springs in the Max Tow, but would like it to more leveled out.  I put a level on the bed rail of the truck and it shows its level...but still doesnt look right.  Anyone have any experience using one of these Equalizer Weight Distribution hitches?  Im curious what settings you have it set at.  I have tried moving the ball higher, lower, adjusting the L brackets....I dont want to have to get air bags, the equalizer hitch is supposed to do the job.
With you truck and trailer on level ground, how much taller is the ball than the top of the trailer ball mount?  These truck do have to squat some to engage the overload spring.
Edited by pewterliftedz
Ive had it higher, lower, currently i have the ball level with the ball coupler.
Edited by BigDog88
Find a good service centre that sells/services trailers, and hopefully the same brand of hitch.  A good technician will help you to properly setup your hitch and probably show you tips and tricks you'd never discover on your own.  You may also need some advice on distributing weight in your trailer to reduce tongue weight.
I may have to do that.  It was originally set up by dealership on our suburban (that came with stock self leveling airbags).  But that hitch receiver was much higher than mine is in the Silverado.  I was hoping someone was currently use that type of hitch and had a picture of their settings.
So how much does is squat?
You can also take it to a truck stop and put it on the scales.  It will tell you the total weight, weight of each vehicle and how much is on the tongue or pin.
I had 1,680lb of block in the bed of my 2020 trail boss.  It had just about 2.25"  of squat.  My max payload is 1,626lb.  I didn't think 2.25" was bad at all.
This is good advise.  If setup properly, the Equal-i-zer will return the rear of the truck to within 1/2' of where it was before the trailer is hooked up.  I have never met a truck and trailer that I couldn't get beck to level.  Whether that is a good idea or not could be debated.  Heck, if your frame is strong enough, you can crank that sucker down hard enough to remove the rear wheels:
This is a good video on how to set it up:
https://www.youtube.com/watch?v=l5TtNUxeFWc
Also, if you could post a pic from the side with the truck and trailer hooked up with the Equal-i-zer and closer in of the hitch itself, we can tell a lot just from the pic.
Edited by corn18
You can look into the sumo springs instead of running air bags. They are maintenance free and replace the bump stops. They are a progressive "spring", so the more they compress down the more work they do to keep you level.
on both of my weight weight distribution hitches the top of the ball should be set 1.5-2 inches higher than the trailer coupler when the trailer is level, you may need to fine tune the angle of the WDH head with a washer or spacer. I have An Anderson WDH and Husky centerline WDH.
I have the fast way E2 on my K2 Silverado for a 3500 lbs camper. Don’t need one but I had it from a previous tow vehicle and it does well with reducing the bounce and the affects of wind and semis. To ensure you set the hitch up properly, do you have the measurements from the squat on the front and rear tires with and without the WDH? Also have you taken it to a cat scale? Always best to check the basics and start with the cheapest options before modifying the heck out of it then buying a 2500!
5 hours ago, BigDog88 said:
Done that...thats why im on here looking to see what others are doing.
How much does it actually squat?  Did you measure it?
Your initial post said "it doesn't look right". That is pretty vague as looks can be deceiving.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
