55k, new is around that price with rebates. This dealer has always been high on their prices. I was looking 4 yrs ago for a suburban. They had a low mileage lt with rear ent. Package, $52k found same 1 with less mileage same packages in ct for 45k
Sent from my SM-G960U using Tapatalk
There is usually a sucker out there who will buy it, which is why they price things like that. And if not, they'll lower the price a thousand or so at a time until another sucker does.   Right now these trucks are in pretty decent demand and the dealers and resellers know it.
Edited by Colossus
https://www.robertchevrolet.com/VehicleDetails/used-2020-Chevrolet-Silverado_2500HD-Crew_Cab_Standard_Box_4_Wheel_Drive_High_Country-Hicksville-NY/4639904093
55K for a $76,000 MSRP High Country Diesel 2020 brand new?  LOL OK.  Please, go ahead and show me one.
https://www.cars.com/vehicledetail/detail/820647575/overview/
https://www.cars.com/vehicledetail/detail/820580046/overview/
At best at a similar MSRP, they are no more than $10,000 off for a brand new one.  Also, used market it kinda F'd up too as demand for inventory is high as is demand for buying.
Markey is wayyyyy over priced right now. Been looking to upgrade camper and forget about those inflated prices. Heres a brand new one for 64kdadeb88cba213be65434d4784b0632e0.jpg
I have no use for a high country and all of that. The used work 2500 trucks are now selling for more than they were new in my area.
Of course talking trucks with 20k miles or less etc. Especially 2017-2018 models.
i daily drive a work truck crew 2500HD.  i have better things to spend my money on than an expensive truck.  i tell the kids just to drop their empty food packages in the vinyl floor, that’s why i bought a cheap truck!
Yup. Have had my eyes on a 2018 2500 with only 14,000 miles on it, but right now it's going for more than it did brand new.  Nope.
It's the same everywhere, used prices are up almost 25% with this whole Covid thing... I started out looking for a good 2 or 3 year old truck in May and ended up ordering a 2021 for the a few thousand more than what I was finding used.
  • 1 month later...
finally back to 2500. really had given up just stick with what I had and get a decent deal on a year older truck.
first time had a dealer cut me a check. 6 hour drive but got to spend some time away in a nice area.
lost a year and had 20k more miles but its done.
check out Hemmings motors, i would look for a 1 owner used model years between 2000-2013  truck with low milage for $25-$35,000 and garaged kept . some people buy these trucks and use them 3 x a year to haul something. they are out there but people want real money for everything these days, there are no deals
2500 HD trucks are getting rare, and production on new trucks is low due to shut down
https://www.hemmings.com/classifieds/dealer/chevrolet/silverado/2443915.html
Edited by flyingfool
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
