Is it a thing that the DEF gage in the DIC will show full when it’s not? I took it to the dealership for warranty work and it was down one green square, pick it up the next day, and I’m sure they didn’t add any, full. I drove for about a week, and just did a 200+ mile trip towing our TT, still full..is it a thing that I need looked at? Or common issue. How many miles you guys getting out of your DEF tank?
2 hours ago, Thankful said:
About a thousand miles per gallon.
I'm getting no where near that but I do tow frequently.  I think that's probably right if just running the highway unloaded.
Definitely keeping a close eye on this on my truck.  Hoping it is just a matter of the system needing a few cycles as per the tech bulletin that redwngr posted in another thread, but I need to get the truck in to a dealer anyway for another issue.
I've never towed.  So you're probably right. Towing will increase DEF usage.
I have the 2020 Silverado 2500 HD and just got back from a 3700 mile trip towing a ~7000lb travel trailer.  I had to fill my 4.5 gallon DEF tank three times so I am getting way less than 1000 miles per gallon!  It eats DEF like crazy. Mine starts giving me warnings that my DEF range is 975 miles about 150-200 miles after I fill it.   I took it to the dealer when we returned and they said they did a software update related to DEF but I haven't driven enough yet to see if it changed anything.
I'm getting about 500 miles per gallon of DEF towing an 8000 lb Airstream trailer. The DEF gauge works well and shows about the right amount of DEF over distance traveled.  It appears that the newer diesels; Ford, GM and Fiat Chrysler all use more than prior years to meet more stringent emission requirements. We're not alone.
Edited by unit
When the fuel usage is increased (like when towing) the def use will also increase, by about the same percentage.
Another thing with this truck...mine is never accurate. They did the update a few months back. I feel like I bought a beta tester vehicle.
I agree, that's why I don't buy first year of a new generation. I'm looking to order a 2021 3500 AT4, barring anymore serious issues.
Edited by SilveradoX2
i had more issues with my 2017 than I had on my 1st 2020, put 40k on it and just traded it in.  The issue here is the def gauge, 2017 didn't even have one, mine has been pretty accurate though and even if its a bit off I really wouldn't call a serious issue.
From the GM techlink article:
Segmented DEF Level Gauge
The current 2020 Silverado 1500 and Sierra 1500 models have a DEF level gauge on the instrument cluster that provides drivers with a representation of how much DEF is in the DEF tank up. (Fig. 2) The DEF level gauge does not operate like a typical float-style gauge that is used in a fuel tank. The Engine Control Module (ECM) monitors the DEF level and consumption rate in order to calculate an estimated range. DEF levels are detected by the DEF level sensor.
There may be some fluctuation in the amount of DEF represented on the DEF level gauge. After filling the DEF tank, it may take a few key cycles to register the correct amount in the DEF tank. With the new segmented DEF level gauge, it is possible that after adding 5 gallons (18.9 L) of DEF that the gauge reads as a full tank after the fill event. However, if the actual level of DEF is just entering the last segment on the gauge, the gauge is likely to drop by one segment shortly after driving after the fill event. As a result, a driver could have an initial impression that the vehicle consumes an excessive amount of DEF.
    • tldr; Shade tree mechanic stumped by variable displacement AC compressor.   Not Silverado related, but for my 2000 Camaro SS. I've never really used the AC since acquiring the car a good handful of years ago. I plan to take it on a trip this summer so I wanted to make sure the AC was in good shape. On an 73 degree day in the shop with the car idling I set the AC on "Max", temp set to cold, and fan on hi. The compressor turned on and air turned nice and cold.   I let it run for several minutes but noticed the compressor never cycled off. The engine was up to temperature enough that it began cycling the cooling fans on high. I had a set of manifold gauges hooked up and it was consistently at about 25 psi on the low side and between 200 and 225 psi (warm engine) on the high side. Per temperature charts, the low side is low (should be 30-35) and the high side is a little high (up to 170 per chart). I read the low pressure as potentially being under-charged underscored by a continually running compressor This was also underscored by temp readings of mid-20 degrees at the vents. Not just cold, freezing cold. Switching off the AC but leaving the HVAC fan on high produced a deluge of condensation underneath the vehicle. I was getting ice buildup on the evap core most likely.   The low reading (25psi) concerned me that the compressor wasn't switching off so I swapped out the pressure switch. No change in behavior, still ran constantly.   The AC clutch works fine as it engages/disengages with the HVAC switch on command. The compressor relay is good as I swapped it with two different known good relays just to be sure. Having eliminated that, and the pressure switch, I added refrigerant, thinking the constant run and low "low" pressure were signs of a slight undercharge. Makes sense, the car is 26 years old and it doesn't appear the AC system has ever been touched.   Adding some R134a didn't meaningfully change the low side pressure. And that's when a lightbulb flashed upstairs. While I consider the car "old", it's possibly "new" enough to have a variable displacement compressor. Did some reading and sure enough. Dangit. I don't work on these for this reason.   Adding refrigerant means the compressor will just compensate and won't really change pressures until it's severely overcharged or undercharged. But at least I wasn't getting ice/frost anymore, but instead high 30 degree temps out of the vents. That's more normal, but with variable displacement now I have no idea where my charge level is at. It's probably overcharged now. The high side even with the engine radiating serious heat was never really over about 225.   The static pressure at room temperature is dead on, before and after the charge. Both high/low equalize after some rest.   I'm thinking I'll need to take it to a shop. I want the proper charge level so I'm not working the compressor too hard. The only way to get an accurate charge is to evacuate and then re-charge with the exact amount specified for the system -- at least that's what I'm reading.   Anyone here with modern automotive AC knowledge?
    • Mine is in the shop for the AC now. While it did get cold after a bit, it would take a while to even start to cool the air at all. Turns out the compressor was bad and cycling.
    • I call B.S. when I first moved to Texas my first house would only cool to 80 with the Texas heat. The AC tech said it was normal at 100 degrees outside. I remodeled the house put in a new AC. I could hang meat. My cars may need recirculating to start. Once moving it switches to regular AC and I could hang meat. Living in Texas no one would put up with only 20 degrees difference.
    • AC in home or auto only cool down 15-25 degrees from outside temp, but what will help is to put the ac in recirc mode this will recirc the Inside cabin air rather then trying to cool down the outside hot air, I always have mine in recirc mode.
    • Found the fix for this.  Untightan the bolt just below top linkage on the steering column, turn assembly left to reduce space between the two linkage rods at the steering column, tighten bolt.  Made a big improvement.
