2020 GMC Sierra SLT 6.2
3,500 miles
Bought new in January and hasn’t been driven much. I decided last week to take advantage of my free oil change before it’s one year expiration.
Dealer changed oil and on the way home the check engine light came on.   Code P106dd.  Returned truck to dealer and they say bad oil pump.  It’s sitting there today with back ordered parts.  I’m wondering is this a known problem with GMC 6.2 engine, and if so maybe I should trade .
3,500 miles
Lol bad oil pump or forget to add oil, did you check to see if they filled it up before it was towed back?
The K2 trucks did have some issues with noisey pumps that had a tendency to go bad. But at 3,500 miles and it happening after a free oil change, i'm thinking your dealer might of been the true reason here.
The code is actually DTC P06DD Engine Oil Pressure Control Solenoid Valve Performance.
The variable displacement solenoid valve if failed will set that code.  2014-2018 trucks its been seen on but almost always with mileage on it, say 70 thousand or more.  Plenty of trucks out there without an issue as well however.  Its not a "common" failure, but there are a couple reports of it out there.  At work we've changed 3 or 4 oil pumps out of the hundreds/thousands of trucks and SUVs with the Gen 5 engine we've sold since 2014.
If you got that after an oil change, a couple possibilities.  Tech put low or no oil in it or wrong oil filter.
Edited by newdude
  • Thanks 1
Guess the 1 between the P and O faked me out :crackup:
Newdude at least on the 14 which is what i have to the 18 model years  do they sound like a 1986 ford taurus with a bad power steering pump? I have been told by some techs that is the prelude to a bad pump and most likely bad engine when it pops, all dealers around me and even my own mechanic claim it to not be anything to worry about but the whine drives me crazy somtimes.
These Gen 5 make noises on day one.  My 2019 old body with 22k on it made noise and still does.  Bad oil pump solenoid you will see the oil pressure gauge either stay high, or not spike up on acceleration over 3500rpm for the second stage, etc.  Its not that the pump is bad, its the solenoid that fails and that solenoid is not replaceable outside of replacing the entire oil pump assembly.
Quote
#14-06-04-004G: Various Engine Noises During Cold Start and Warm Engine Operation - (May 27, 2020)
Direct Injection (DI) / High Pressure Fuel Pump / Fuel Injectors
The new Small Block Generation 5 engine family incorporates a new fuel system technology known as Direct Injection (DI). With DI, fuel is injected directly into the cylinder using a high pressure fuel system. DI provides many benefits in improving engine efficiency. In particular, DI improves power, torque, and most importantly fuel efficiency. This technology is included as standard equipment on all Generation 5 engines in the Small Block engine family, which are the 4.3L V6, 5.3L V8, 6.2L V8 and the 6.6L V8.
The high pressure fuel system does have unique operating characteristics, in particular the noise emanating from the high pressure fuel pump can result in a subtle ticking noise that is apparent when the vehicle is idling. The sound is more evident when outside around the vehicle, when the hood is open or the vehicle is operated in a drive-through. The sound may be more noticeable during a cold start, but lessens once the engine is warm. A slightly higher pitched clicking sound is the fuel injectors pulsing ON and OFF under the high fuel pressures.
These sounds are a normal characteristics of the DI high pressure fuel system.
Another operating characteristic is a slightly longer crank time when the engine is started. The increased crank time is the result of the time required to build high pressure in the fuel system before the engine starts.
Oil Pump Cold Start Rrrrp or Rasp
The oil pump design has changed from a gerotor gear type pump to a two-stage vane type pump for fuel economy reasons. At temperatures at or below 0°C (32°F), or when the engine has been sitting for a few hours, it is possible to have air enter the pump through normal oil drain back. Upon startup, the owner may hear a short “Rrrrp” or “Rasp” coming from the front of the engine. It is most often heard during a remote start.
There is nothing wrong with the oil pump or oil system. No repairs should be attempted for this condition.
  • Thanks 1
I checked oil before I left dealer.  Truck never ran bad at all. Just check engine light was on by the time I arrived home.    I cleared code and drove truck to dealer the next morning.  I spoke with service rep and discussed oil weight and possibly wrong filter.  Mechanic ran test while I was there and told me filter was right and all testing suggested oil pump.
Yea , strange it all happened after oil change.
Thanks for the replies, makes me at ease about my truck.  I was concerned GM might have a problem with pumps.  Glad to here that’s not the case.  If I may ask another question about replacement of pump.  Is this job assigned to just any tech , or is this job better served by a seasoned tech.  The reason I ask is the tech assigned to repair my truck is fresh out of mechanic school and is 20 years old.
I will keep this post updated.
Its an A tech job.  It could be a 30 year old doing it, but a trained 30 year old.  They aren't giving it to the brake job gravy king to do.
  • Thanks 1
Just back from dealer. Truck still not ready.  I did walk to where they are working on my truck to take a look.  Truck is on the lift, and it’s looks like the front axles are out plus oil pan radiator and so on.  It must be in a hundred different pieces.    Said may get it back together by this Friday.    I m beginning to think this truck will never be right again.
today starts 5 weeks it’s been in their shop.
Edited by johnnypayne66
Update down time.
No reason to worry until there is a reason too :)
When you pick up the truck, ask for additional warranty on the drivetrain and go home with a smile knowing that your covered for an additional period of time above and beyond the normal.
Picked up truck just a few minutes ago.  Everything seems normal.  Oil pressure 40 psi hot, cruising almost 60.   Fingers crossed, and thanks for all the replies.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
