5 hours ago, tlaw91 said:
Keep both feet depressed on the pedals when cranking.
Let off to get out of clear flood.
This post is about bad battery cables and how to test them.
I’ve never seen bad dash grounds. Never fixed them. And I work on 5-10 vehicles a day.
There is no body ground near the starter.
OK tlaw91.....to clarify my comment about the ground down by the starter, I'm referring to the (2) grounds that are mentioned in the below video....Passenger side, ground to body.
2014 Silverado no crank no start problem solved!
On the dash ground(s) please watch this video. I think GM finally fixed this issue on later truck but lots of Chevys had this issue. (Both sides)
2014 Chevy Silverado electrical issues and Stabilitrack issue FIXED!!!!
A bad ground will cause ALL kind of electrical issue, from no start to all the other little gremlins. Just like an old or bad battery AND bad battery cables as you mentioned. Some people have even gone to adding additional (heavier cables) grounds. Always use dielectric grease to all electrical connections when you have them disconnected.
Hope this helps clarify my questions. Again, thanks for your post. It's good info.
Dude had a rare issue on the early 14’s.
I’ve never seen it/never had it fix anything.
Please avoid using dielectric grease for anything other then spark plugs.
If you must use something use dielectric lubricant. Mostly used on micro 64 and micro 50 connections for terminal fretting issues.
Delco p/n 10-4064 grease for high temps and voltage. Think spark plug boots.
Delco p/n 10-4071 lube for low temps voltage. Think 12 volts and less.
Edited by tbarn
Replacement cables? Are there heavier gauge, finer stranded, more insulated, higher quality connector type cables to be had? Which ones, exactly do you recommend? The variations in different brands and caliber of manufacturers is like anything else, they vary wildly. Which cables should I Buy for my 2015 L86 High Country? Please and thank you.
Factory cables
  • txab changed the title to How To: Strange electrical issues with 14-18 Sierra/Yukon? Do this test first!
8 hours ago, tlaw91 said:
Factory cables
If you wanted you could always have a replacement set of cables made with proper crimp connections rather than doing it the 'ol shadetree mechanic way.
My neg cable didn’t even register a DC mv reading. My pos cable was 5.53 with a jump to 11.65.
Got a low battery alert which also notified onstar? after doing this test. I got an diagnostic email lol. Battery voltage is 12.62 so maybe my battery is weak? Or my random service stabilatrack message is a different issue.
None of what you just said sounds like you did the test correctly?
But if you cranked your truck for less then 30 sec then you got a low battery message then you need a battery ASAP
Check the ground connection on the frame, behind the passenger side front wheel, beneath the wheel liner towards the bottom. You can just hold it back. Requires removal of nothing if you turn your steering appropriately.
Remove the ground bolt, clean up the mating surface, put it back, and try that for a little while.
1st pic was what it looked like from factory after I removed 10mm bolt and neg cable. 2nd and 3rd pic after I wiped off wax with a paper towel.
Will have to give it a few days or weeks to see if I get service stabilitrack message again.
Nice.  I wire wheeled the mating surface on my Yukon, then painted it once reassembled.  I did a better job than the dealer tech did which is why I investigated this after receiving back from the dealer.  So my problems were either THIS ground or the ECM as both were dealt with simultaneously.
For you it is worth a shot.  As far as I know the G218 ground issue in the upper dash with insulation being pinched between the wire and vehicle body was dealt with and potentially only affected 2014-2015 and possibly 2016 truck models only.
However if you wanted to double check G218, feel free for your peace of mind.  There are aplenty write ups for that one which show exactly where it is.
Edited by BlaineBug
Update: cleaning the wax off frame and negative cable didn’t solve the random service stabilitrack message. Still had a month of warranty left so took to dealer. They replaced negative battery cable due to high resistance. Hopefully that solves it.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
    • Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
    • 3.15 Kroger’s in Montgomery Tx
    • I have a LTZ and it has the shifter in the console, which I like, but, every now and then, it will not stay in Reverse. I go through all the motions, hold the button in, push the shifter forward and watch the dash.  The big red R comes on and also the back up camera.  Then, it just pops out of Reverse with the shifter all the way forward.  So then the game begins.  Back and to Drive, Reverse.  This goes on 8 - 10 times. Very frustrating. Had it back to the dealer and they replaced some kind of computer, but it is now happing again. It is so bad, my wife will not drive the truck, she is afraid of being stuck somewhere.    Anyone else with this PIA problem?
    • I see where you’re going and I can appreciate that. Statistics can be misleading because of the word average. They say statistics show the average cost of a new vehicle is about 50k. The average monthly payment is close to 1000 dollars a month. That’s statistics for you. I know very few people who pay that.
