Ryan,
That looks interesting.  I can't comment on the Gen5Diy setup but I followed this thread and it worked perfectly.  Takes a little more time but only costs about $17 in parts:
On 2/12/2021 at 12:24 PM, RyanbabZ71 said:
just ordered, I've been waiting for this - curious to see what modes it operates in.
Following this for sure. It’s -5 degrees out so I won’t be doing this until spring or whenever the hell we get some kind of winter thaw but I will also be doing this
Does this override the cargo lamp switch or is this for additional lights under bed rail?
If it’s basically just a splice, I’m thinking about using it for some rear flashing beacons instead of the full upfitter getup.
Where do you tap in for the bed lights/cargo lights.? In the video they show were to get power in the trailer harness but that’s all I see. Am I missing something?
Yeah, I was looking at the same thing.  They show you the harness poking out of the hole, but don't show you putting the tee into the bed light harness.
The bed lights can be installed after the truck is built, so you just need access behind the driver's rear tail light.  See this guy installing them:
My assumption is you pull the tail light, unplug the bed lights, plug the new harness in between, and also up through your new hole in the bed.
Also, since you tap into the trailer harness for power, assume you are backfeeding the system, so you are taking the interior switch (and it's power distribution module) out of the circuit.
Got the kit in the mail today, there are no further instructions included on what to do with the other connectors.  I sent them an email asking for some, I suspect you guys are correct tho - that it will connect via the bed light connection.  If I get an answer I'll do the install this weekend and take some pics along the way.
  • Thanks 1
Would greatly appreciate the photos.
How long did it take for you to get yours?
Ordered on the 13th, arrived today.
Then mine should be here soon, I haven’t received anything other than my order confirmation from them. And now if you go on their site it shows it being sold out.
Received this email from Gen5Diy this morning, which might explain the sold out status.
 we may have discovered an issue with the build of this harness.  I am going to send you a return label today for it.  When we designed it, it was originally for the old body style.  The new body still uses the same connections, however we just learned that the lights are not wired in a loop as in the old body.  If this is installed, only one cargo lamp will light off of our switch and we know that is not what customers are after.  We will get it back here and change the design for you and get it back to you.  I apologize for the inconvenience
Well damn, wish they send out an email to people who orders are pending
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
