Is it still possible to replace just the blade in the windshield wipers? Or is it better to just replace the whole thing?
I would suggest swapping the set to a new blade.  I prefer the Bosch brand of wipers.  Their premium line is the best I've used and last a long time before needing to be replaced.
I'm not sure if you can just replace the blade though.
For the longest time, I have always replaced just the rubber insert. But over the past few years, the rubber inserts are getting harder to find. And now there are multiple widths. Costs a little more, but much easier to just replace the entire blade assembly.
You can certainly get the inserts out.  I haven't been able to find anything to put back in.
Although I haven't been looking too hard.
I've been using these.  I'm happy with them and even with shipping, about half price through RA than at the store.
https://www.rockauto.com/en/moreinfo.php?pk=11105973&cc=3443204&jsn=2535
I'm sold on OEM Direct Fit Replacement myself. Keep the windshield clean and don't run them when frozen to the windshield and they last for years. Makes that $20 price seem a bargain. Wife and I have 270,000 miles between us with once change of blades each. I just put the third on the passenger side of hers. Started them frozen and RIP...
GM has three tiers
OEM Direct Fit ... ACEDelco Advantage ... Professional
GM has three tiers
For some reason I’m not finding anything on OEM Direct Fit, any chance you have a link?
Agree with GB, the factory blades are awesome when new, and do last quite a while.
Found this part number, not sure which level (did not know there were) it is: Blade (Replaced Part Number 23387857) - GM (84578275)
That's the number listed in the owners manual
Take your VIN to the dealer and ask. It's what I do.
Tell him you want the part the factory used to make the thing.
Not a fan of the OE wipers on the 2019 and up trucks. They downgraded from the nice beam design on the K2s to an old school spring arm with aero pieces tacked on.
Maybe the curvature of the windshield required it, or probably it’s a cost thing. Either way, nobody should pay $20+ a pop for those pieces of crap. I ditched them within a month because they lifted at highway speeds. They are ugly too.
Bosch Envision are the best I've ever used.
I agree with Grumpy here. I have been through many different brands of wiper blades and never found the best wiper blade other then OEM from the dealer and there right about the same price as the brands off the shelf. One thing that bugs me is wiper blades that make that flip flop noise going back and forth  across the windshield.
A good cleaning and a 2X application of Rain-X will stop that. ?
Same here and I easily get a year out of them. Probably because my vehicle is so often garaged.
Edited by Minnvmax
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
