I have a little over 5000 miles  on my 6.2  On 6.2L engines (RPOs L87, LT1, LT4 and LT2) built from June 1, 2020 to October 7, 2020 does anyone with that build date have a lot of miles and no problem yet?
2019 High Country, Purchased 12/23/18, 30k on it currently.
2020, 6.2L, 10 speed, AT4, purchased about June last year. 13k miles with no engine issues.
Had a weird situation once where the engine wouldnt crank or start. Disconnected the batt and reconnected. Was all good, probably electronics related. Hasn't happened again. [emoji2369]
I also  put on  a pulsar lt, so far so good, gas mileage went up from 16 mpg to 21 mpg. If you have the extra coin I highly recommend it. Hopefully my valve springs are good. Thanks to all the guys that have posted
2019 with the 6.2 and only have 18k.  Since we moved and l lost my job the miles will not be adding up so fast as they did before.
Can you expound a bit on this HUGE mileage increase? How has your driving style changed before and after? What stage tune setting do you get this mileage increase, 1-5? I assume this is highway MPG? What speed do you run?
Thanks.
Thanks.
On the hwy at ~10-15 over the speed limit I average between 19.5 and 20 mpg in my 6.2. Lifetime right now is about 18.5 through 4500 miles. 45c72549f0330ef630553f4bea5c4eec.jpg010cc22a49f8f1d55b97f4bfb7318177.jpg
2021 6.2 LT TB purchased in with 4K miles. Valve spring went out at 197 miles. A month later all the springs were replaced and I haven’t had a big issue since. My parking sensors still kinda work sporadically and the dealer hasn’t been able to fix it. Although lately the error pops up less and less.
For those getting 20mpg, are you guys/gals driving super conservative/all highway?
I'm at about 13mpg mixed. 18mpg running cruise control on the highway...trying really really hard.
I'm on my second engine here and neither of them hit 20 over a long haul.  I have a TB so it might factor in a bit.  To @awesome barney, I think it has a bit to do with how he was driving and/or where.  This is NOT a programmer/tuner.  It only modifies the info coming to and from the control modules.  If this were true, GM would be hopping all over it to keep their overall MPG down.
It does is no good to know how fast over the speed limit you’re going. What’s the speed you are traveling? Here in Utah the speed limit is 80 mph so your mileage is going to be much different at 90-95 mph as opposed to somewhere that has a 60 mph speed limit and that person is running 70-75 mph.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
