5 minutes ago, JimCost2014 said:
Buy the RAM, then you don't have to worry about tearing apart a new $75,000.00 truck to make your kids happy.
RAM comes up short in almost every other respect. Just my assessment and opinion of course.  And I won't be tearing apart anything.  That's why I'm asking if there was a solution that might have been simple. Looks like probably not.  Have a great day JimCost2014 you deserve it.
33 minutes ago, Jac365 said:
Double cab rear seats do not have the storage in the seat back. I don't know if they are interchangeable with crew cab seats or not. I have a double cab with leather.
Good call. Not sure if they would be same either though. Might be worth it for the OP to look into.
Ram Schmam.  When a farmer see another buy a  Dodge, he know he didn't have a good year.
Remember, you asked for solutions, and opinions, which I gave both.
If it makes everyone inside happy, don't think the brand really matters.
I'd like to thank all of you for assisting me.  I know it's a problem only I would create but I will certainly look into all the suggestions.  The GMC was in a different league for sure.  I've never seen a truck that nice, and I'm blessed beyond measure to be in the position to own one.  Thanks again gents.  I'll report back.
Edited by vinny canalie
True. I appreciate it too.
Probably a low tech solution, but have you looked at pillows that they could use behind them? I know it's not ideal, just trying to think outside the swap route.
Definitely a solution. I'm going to drive the Ford just to check it off the list first, then think long and hard as to whether or not this is truly a deal breaker.  And likely pillows, or some type of seat back cushion will probably be my answer.  Thanks sir.
check out the Tundra and the funky Titan too
ford v6 is a disaster to own long term, lease em all (Ford, Chevy, Dodge) and trash after 6 years. support is gonna be going away fast , 2030 is roughly the end of 1500 trucks...
Edited by pokismoki
Its always funny to me how people are so different. We tested a Ram 2500 first, but my kids hated the back seat. We've owned our GMC now for 4 months and no issues. I sit back there a lot now as my daughter is learning to drive and my wife still sits up front. That leave me in the  back with the other two kids. I haven't been on any long trips back there, but I don't find it uncomfortable. It's also funny to hear people basically say their kids don't matter. They do! Unhappy kids in the back seat on a long drive can easily ruin a trip. Good luck man.
Maybe remove some of the padding from the cover in that area?  upholstery shop should be able to handle without too much issue.
My truck is my daily driver. I'm also the primary caretaker of my children. Therefore, they spend more time in the back of my truck then in the back of mom's SUV. I've been on many long trips, and had the kids in the back seat. One of those trips was east coast to west coast. None complained about the rear seat. Personally, I love the rear seat storage. That's where I keep handguns. I'm not kidding. A handgun and a few loaded magazines in each compartment. Since you mentioned you go on long trips with the family, I instantly thought of camping and couldn't help but think how a 10mm in one of those storage compartments was ideal for camping should an uninvited predator come to play.
Good stuff.  I appreciate you sharing first hand, with kids.  I love the idea of stowing a handgun in there.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
