I'm sure it sounds silly, but man those are annoying to get out to clean.  Do you guys vacuum/wipe them down without removing them?  Any tips on making it easier?  I took them out once and swear I can't get them to re lock together as well as they were from the dealership.
I just vacuum and wipe them down with a wet rag real good. I assume you are speaking of the rears? I don't have a lot of people in the back of my truck that much anyway, so it does not get very dirty at all. Yes, they can be very annoying to reinstall.
After a time or two it isn't bad at all getting them in and out and back together.
Other than that shopvac and wipe out like mentioned.
-Grover67
Edited by Grover67
They come apart and relock better in warmer weather. The winter is a wipe down. Maybe next winter will be better after they have been broken in.
I just cleaned mine yesterday. They really weren't difficult at all to get out, or to get back together. One thing I did notice is when you push them back together at the locking points, they go back together a little easier if you put outward pressure on both mats. Hard to describe, but basically push outward on both mats away from where they meet. I've found that helps them slip together better.
Also, for the cleaning itself, a little carwash soap and a soft bristle brush attached to a cordless drill makes it real easy.
I've been considering getting rid of them for the summer and/or when I don't plan on getting muddy.  They remind me of a 9C1.  60k+ truck with plastic floors?
99.99% of these are mall crawlers
Edited by Rob Mugs
My dogs are back there a lot.  I got the full coverage mats because of this. Honestly, makes little sense to clean them when the dogs dirty them up quick.
For me, I just take a rag and cover the door hinges (keep grit out) then use the leaf blower.... bam.... 10 second job.
I have kids. They sit in the backseat. With kids come messes. Those nurses occur in the backseat. Therefore, I have these mats. When I take my truck to the carwash I pull these mats and clip them to the wall. I then high pressure spray them to get all the grime, gunk, and garbage off them. I throw them in the bed of the truck once in done with the carwash, and then let them hang dry at home in the garage. Once they're dry they go back in the truck (following a vacuum of the interior, of course). Never really had an issue with getting them to interlock.
Do you have the under seat storage?  That seems to be the trickiest bit.  They slide slightly underneath and it's snug
Yes. I'll be upgrading to a Du-Ha shortly.
I never thought of taking the rears out.  You guys get them that dirty?
No. My kids do. It's my truck, and I want them clean. Kids don't give a F.
I use my 40v yard blower to blow out the dog hair and other debris, with doors open.
Then use Adam’s interior detailer with a soft rag. Ends up looking like new. I also blow out the door pockets.
My 2 German Shepherd dogs shed a lot.
I have never removed mine. The driver door is the only one that gets used hard and I have lifted it to vacuum the edges. The top is nasty from winter. I always keep a floor mat down to cover it up anyways.
I vacuum first then I spray it down and wipe with the meguiars carpet and upholstery cleaner which is foam comes out very clean without having to take out
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 888 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
