What it is the opinion about changing transmission fluid in a truck not used in "extreme" conditions?  Daily driver, hauling stuff when needed, etc,,.  Have a 2016 HC just hitting 60K miles.   Having no issues and want to keep it like that.  It would be done on a regular service visit (dont give me crap, I am physically unable to get under the truck and do this).
Bob
Change it. Give me a reason not to.
  • Haha 1
OK, here's my opinion. (keep in mind, others may not agree, but you asked) I do a "drain & fill" every 30k miles, no filter change. I do not crawl under the truck, I suck the old fluid out the fill tube, approx 5 qts & refill with full synthetic Dexron VI, as I have the 6L80 6 speed transmission. I don't know what you have (6 or 8 speed) I believe the 8 speed takes a different fluid. This method is quick & easy, rather than fighting the exhaust pipe that is under the pan. I also did the "transmission thermostat bypass" mod just to keep the temp of the fluid lower. I bought my truck as a used Certified from Chevy dealer with 30k on it. I've actually done this 'drain & fill' at least 2-3 times to make the overall change effect better/more complete. The filters are very porous & do not filter out the small crap, just the big stuff & I have never seen a clogged filter even at 150k. Most small stuff will settle to the bottom of the pain & surface tension will keep most of it there, which is non magnetic. the magnets take care of the steel particles. Just look at a pulled pan. Anyway, that's what I do.
Iv usually half the recommended. You used to be able to go by the smell test. I would either go through the fill tube or drop the line. Seems their doing away with the tube. And now there’s thermostat in the line. So you have to go under. I’ve never done a flush, just drain and fill. Usually repeat a week apart to be more compleat.
Edited by KARNUT
Bob
IMHO Bob there is no such thing as 'normal' conditions. All service is extreme. Ever since GM put thermostats on transmissions. Did my first drop, filter and fill at 50K and the OEM fluid was done. I've since done the pill flip, done an 8 quart pan with a drain plug and several drop and fills. Every 25 K I do 8 quarts.
  • Like 3
I'll be doing this on my '17 6 speed today in anticipation of a trip NY-Key Largo next week.  Not going to pull the pan for filter, though; just remove the drain plug in the stock pan, drain out the fluid, and then pour in the ~6 quarts of new Redline D6 with a half bottle of Lubegard Red.  The fluid change is a 10-15 minute ordeal.  The fluid was last changed about 14k miles ago.  I recently "flipped the pill" so even with the short OCI, the fluid has been heated.
In my manual on the 6L45, GM lists the ATF replacement at 45k, or as little as 15k miles under "Extreme" conditions; I'm assuming the same holds true for the 6L90.  That transmission runs about 20*F cooler than the 6L90, too.  It is interesting that the manual specifically calls out "stop and go" driving" as extreme.  I'm not familiar with the 8 speed.  So, I agree with the above posters; there's no viable reason not to change the fluid, other than risk of fluid contamination.
Edited by 16LT4
Yes change it out.
I do a full ATF fluid exchange out on my new vehicles at 10k miles and switch it over to AMSOIL fluids.  Then at 50k I drop the pan and replace the filter and top off the fluid.  Next 50k I just drain the pan and top off with fresh fluid.
I did go a little extra on my 2002.  Got busy and just plain forgot and dropped the pan and fluid change at 100k miles on the fluid.  I did send off a sample and it came back good.
Take care of you transmission like you do the engine and life will be good.
  • Like 3
Despite the mileage, the fluid came out darker than expected. I also replaced the drain plug as its gasket was flattened and hardened. It took 5 quarts of Redline D6 and a 10 Oz bottle of Lubegard red; I wouldn’t run a transmission without that.
Dealer told me they don’t drop pan anymore, they have a machine that takes 1hr to flush.  I like that better.  Had it done.
I found out about a year ago that the filter for six speed in the Terrain requires transmission disassembly to replace.
:wtf:
You have a drain plug on your tranny?
 Yes. Hence my drain and fill taking 45 minutes less than yours, and in the comfort of my driveway. 😁
Edited by 16LT4
The market for Transmission repair is forecast to reach $259.8 million by 2025.   OE lubes often are equal to the performance quality of the cheapest aftermarket oils. It does mean just because GM installed it its the best lube, it only means its good enough for GM.  Look at all the problems with the ATF on the 8speeds.
  • Thanks 1
11 hours ago, elcamino said:
The market for Transmission repair is forecast to reach $259.8 million by 2025.   OE lubes often are equal to the performance quality of the cheapest aftermarket oils. It doesn't mean just because GM installed it its the best lube, it only means its good enough for GM.  Look at all the problems with the ATF on the 8speeds.
Can I get an "Amen"?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
