Pulled trigger on diablo 7222 - r. Mainly to disble afm/dfm, read codes and change tire size.
Kind of wondering if programmers when used with canned tunes can damage engine or lead to premature wear/problems? How safe are these newer programmers assuming you dont go trying to customize a tune?
Havent seen much posted on the programmer but i can report back how it works if anyone interested.
I’m interested! Tell me more. Is it worth the $600+ ???  Can u tell the difference? What was the down time?
I had a Hypertech on my last truck and loved it. Gave it (from what Hypertech said) a +27HP difference from stock with all stock parts. I had exhaust and S&B intake and it would let loose the 22s at 30 if I stepped on it. Set governor to 130 also. Went in for service switched it back over and never had an issue.  The nice thing was it only cost $325!
Thanks
Thanks
Just got in mail, gotta send computer out and do the whole swap. So not sure yet
Ok. Sounds good. Keep me and everyone posted. Congrats. Take care.
I'd be interested on your feedback as well. I've been thinking on going this route to address the couple codes from headers.
I bought a back-up ECM to tune, as I couldn't do without my truck, even for a few days.
We’ll got it back and plugged it in, few hiccups but all is good now.. the Diablo guys helped get everything sorted out
Edited by lpg
What does a replacement ECM cost?  It might be better to buy a second unit to avoid the downtime and expensive shipping costs.
It specifically says on Diablo's website you have to send your ORIGINAL ECM, you can't send them a different ECM. You can't swap another ECM into your truck as a backup either as it will freak out having a different VIN in the ECM than the other computers in the truck. I see the rest of the Holley owned companies now offer the same setup.
Also the chip shortage probably makes it nearly impossible to get an ECM.
Jay
I picked up the ECU for $250 and would have it reflashed to my vin.
I can always resell it if nothing else, but having it to tune, whichever route I decide to take is far better than not having the truck to drive for me.
HPtuners vs. Diablo looks to be an expensive decision either way and weighing out the pros/cons, since I've had discussion with local tuner, on the HPtuner side and prior to looking into this Diablo option.
Edited by DenaliSS
Spelling
HP Tuners does a hack job and bypasses the encrypted chip in the ECU with an older non encrypted one. Diablo Sport actually cracked the encryption so it's all software based.
I wouldn't call it a hack, that's a perfectly good way to get around that feature. It's no different than doing that stuff to PC computers.
Did you speak with an engineer at Diablo to see how they doing it?
The C8's are still on lock down for now because it's like a rolling code encryption that GM has.
The older chip isn't as powerful as the new encrypted ones from what I was told by a person from Livernois which is why I would call it a hack. Lingenfelter is using this in their tuning attempts. Livernois is working on cracking the software encryption. I haven't spoken to anyone from Diablo but did some research on how they were managing to bypass the encryption and it requires some special equipment to bypass which is why you have to send in your ECU to them. Then you can use the hand held unit to program like you would the older vehicles.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
    • Very often the part number on the trim part is just for the vendor order/assembly plant and will not show up in the parts system.  They won't make a bunch of extra parts that were not ordered. Keep in mind, lots of these parts were made to be "just in time" parts meaning they were dedicated to a vehicles ordered and sequenced for assembly.       Also, trim parts will often say, paint to match.
