What is the highest Dot rating brake fluid that I can use in my 08 GMC 2500hd duramax? Original spec is Dot 3, but wondering if I can use a higher boiling point fluid.
DOT 4.5 is THE Highest you can go. It has a slightly higher boiling point, still synthetic.
Hello, any DOT 3 will work, brand is irrelevant.
I just flushed mine. Picked up 3qts of synthetic DOT 3 from Autozone at motor trader for $4.50/qt. It's not crazy expensive for good synthetic brake fluid as I sought.
I'm with Nick on this one.
DOT 3 and DOT 4 Synthetic Brake Fluid BFLV - AMSOIL
This stuff has a higher boiling point, both wet and dry than the threshold spec of a 5.1
