51 minutes ago, diyer2 said:
I thought 85 was acceptable because we have less oxygen.
Yes sir that was true in carburetor days. New DI and computer controlled naturally aspirated engines can adjust so well it’s almost like a turbo or super charger ramming that lack of partial
pressure back into engine intake.
The laws allowing low octane are literally from 1940’s.
Less barometric pressure actually. O2 has to do with AFR. 😉 85 is fine at 5,000 feet IF 87 is at 500 feet of elevation. There' is a table for that. Problem is; the OEMs that still make SI-ICE's are using lots of boost AND high static compression ratios which are crutched by VVT/VVL systems to limit peak cylinder pressure. And sir they are running on the ragged edge. Enough so that they have become sensitive to even the amount of calcium in the oils add package. Also becomes an issue filling in Denver with 85 then running that tank to Dodge City. And they want to push it further so that the ragged edge becomes off the cliff.
  • Thanks 1
I have used 85 octane for years in everything from vehicles to lawn mowers. Most owners manuals spec 87 octane. I have used 85,87,and 91 (the octanes available) in various motors, not worth the cost.
My carbureted Mercury outboard ran the same on all octanes, it was jetted for altitude.
If they don't need it, they don't need it. :)
So what’s the actual truth on E85’s impact on engine oil? It’s commonly stated in the tuning communities that you should cut the interval in half on the corn. Possibly due to increased fuel dilution. Reason for dilution seems unclear, unless it’s only because you’re burning ~30% more E85 to match the same energy level of gasoline?
On the other hand, the study linked earlier in this thread seems to conclude fuel type bears no impact on oil. And others say E85 actually keeps the oil cleaner and would theoretically extend the interval…
Sample on right is on E-10 Regular and the one on the left is E-85.
Both 5K OCI. More than half the water for both oils is O2 bonds of Ester bases. The KF water test reads it as water but it isn't. Both are normal readings after that is taken to account.
Nothing on this report says change more often. Nor does it say run it longer. I ran both to a 50% Base reduction.
The slight reduction is some wear metals had more to do with the SAE grade. First test was 0W20 and the second test was 10W30.
  • Thanks 2
Combustion dynamic improved from test 1 to test 2 in this data.  That means engine tune up level was improved in test 2 since you see 2 orders of magnitude LESS of nitration 0 % gasoline fuels dilution in the oil and we know that E85 can vary for actual gasoline/ethanol content.  Bottom line get a IC engine to burn clean, get better wear control and less stress on the oil.  Ethanol does burn cleaner in an engine that is optimized and burning clean.  Good work Grumpy.   Big oil has lied about anhydrous ethanol as a "top treat" additive that is low cost high octane and CLEAN BURN.
Thats false in a well tuned engine. More ethanol = less stress on modern engines. Higher octane, natural solvency, cleans up the crap deposits remaining from current gasoline formulations.  Ethanol will not heal a poorly tuned engine, fresh properly operating plugs, boots, coils, wires, 02 sensors, EGR system, PCV system, clean air filter well sealed, MAF/MAP working correctly.  What ethanol does do is clean injectors to a degree. Polymer additives can clean what ethanol won't remove.  Once you damage by deposits the tip of a DI injector it can be permanently damaged and never spray properly so getting that burn best you can will make up to a degree for that imperfection.
  • Like 3
  • Thanks 1
Indexing Numbers FTIR are given as abs/cm2, an integration of the area under the curve between two wavelengths of the infrared spectrum not in powers of ten (orders of magnitude).  A unit of area, not a base ten multiplier.
In point of fact, that number is neither qualitative nor quantitative. It cannot be converted directly to a quantity, such as ppm or percent. But could be indirectly and loosely inferred by knowing the entire area of the total sample over the entire spectral range OR by comparative sampling as is done when estimating fuel dilution by this method.
In such a comparison the reference oil would be run and compared to that same oil with known dilution references. Sample results from volume or weighted prepared samples. Under those conditions the absorption peak could be assigned a percentage. Even both those methods can be in error by as much as 10-25% according to some sources from species created during the oils life cycle that are NOT products of Nitration reactions.
That said these numbers power to see into the condition of the oil is 1.) In its statistical values such as trend to the mean, std deviation and 2.) Comparison of values to long term conditions such as perhaps deposits/corrosion, etc. in like architectures using similar strategies, conditions and products. You might be able to, with enough information make some assumptions that prove true more than not. That is, set boundaries. Boundaries by nature will differ from lab to lab as they are often compared to the subjective and not objective. What a person is willing to tolerate. Some people will walk to the edge of a cliff and some like to stay a mile off it. Boundaries are often set by $$$$ considerations such as ROI.
One thing I like about Blackstone is the unit references given. Typical values over X units for the type. What is being seen as normal for a LS1 isn't the same as what is seen for a Dodge Hemi. They have other flaws that are weightier but.....
There are proprietary methods of FTIR and near infrared that are not published as standards.  When looking at nitration in general it can be contributed by many differing components but when looking at nitrous oxides its very accurate.  JOAP does a better job standardizing ASTM level FTIR.
 Looking at nitration from other sources including CLEAN oil and thinking that area via ABS is subtractable from fired IC engine oil analysis result and be accurate is an incorrect but common assumption.
As I have shared before we can use FTIR for unknown constituent analysis and there are vast data bases for that.  Once you fire a IC engine that game is over.  ASTM and others have yet to fully standardize the nitration realm.  One reason I had a unique business!
Blackstone indeed has no real combustion dynamic reading capability and is blind to IR readings which are a must for accurate oil analysis.  Centrifuged solids testing is good but not accurate enough to what insolubles we see. Blackstone analysis is a bad example unless one wants to just feel good about taking a sample.
I wasn't questioning accuracy. I questioned the math.
I questioned the math not the methodology.  But as I am now forced to look.....
https://www.perkinelmer.co.pj/Portals/0/resource/products/ft/pdf/The_JOAP_Method_for_OIL_Condition.pdf
Okay now I have an idea of method.
[quote]
The JOAP method differs from the reference method in that it provides absolute values for components of the oil. [that means without reference to the new oil] The method involves the subtraction of an empty cell background from the used oil spectrum. Characteristic regions from the resulting spectrum are used to determine used oil parameters and components (Table 1). [end quote and bold insert mine].
JOAP (Joint Oil Analysis Program) [Military protocol] method has nothing to do with accuracy or "type" of nitration compounds. No magic going on here. This is straight up error control. A method to eliminate errors in interpreting samples by elimination of the 'possible source' of error. That is knowing the base oil reference. Example given in the link is oil additions during the oils life effectively canceling the VOA values. Has nothing to do with Voo Doo happening "once the engine is fired". AND it's still an integration of the area under the curve. If fact that pdf the problems are in collecting and categorizing not is the result of the FTIR. Same number either method.
ASTM E2412 INDEX Number Reported is also without reference to the new oil. Subtractive analysis is the comparison of the two reports and not the report or method used itself. Both methods ASTM and JOAP read the same spectrum, Nitration, and against the same scale. A/cm.
If there is anything that seems magical going on it is in the point of condemnation. The lower that number the cleaner the oil the longer the equipment last. Few gasoline or diesel motors ever die of Nitration. Natural gas motors are where this is an issue. You like 10 absolute. Some labs are 10 over the background and a few at absolute 20 A/cm. The bigger the number the longer they claim an oil 'okay'.
When enough mud gets on a floor so that I can no longer see the floor. I give it a clean sweep. I'll keep my ASTM E2412 and note my baseline comparisons.
Edited by Grumpy Bear
[quote]
Good Luck!
  • 1 month later...
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
