So initially had cyl 7 lifter fail at 55k miles and I had afm turned off since I had 8000 miles.   I returned tune to stock before shop replaced all lifters but not the vlom.  I picked it up truck and dove home a couple miles afm was coming on and off lie I expected it to.  I retuned it and turned off afm that night.  I drove the next day running errands then 3rd day it was feeling like it was hesitating again like when I had the intital lifter fail.  So I did a hard acceleration and sure enough check engine and engine bogged down exactly what happpened first time I had a lifter fail.
I returned ecm to stock again and he towed back to his shop and I printed the bulletin for him about replacing vlom with lifters.  So basicaly he replace the failed lifter again and he had misfire code again then he finally replaced the vlom but still misfire.  He contact GM engineer who likley told him the his replaced lifter would need to be replaced again.  WHich he did replace the lifters a 3rd time and this time with the new VLOM and he said GM engineer tweeted some of the computer setting.  I have had it back 4 days and put on 150 miles and no issues and this time I didn't turn the AFM off right away.
I am wondering how I had a failed lifter with new lifters and turning afm off right away.  Was the solenoid still activating even though afm was turned off or was damage done when shop test drove and I drove home on the old vlom and new lifters?
When AFM is turned off with a tuned the solenoids do nothing correct?  I want to turn afm off again because I hate it in 4cyl with my exhaust but nervous since the shop told me my turner could have caused the second failure but I think this is BS.
I am assuming they just botched the install. That is BS that the tuner could have caused the second failure.
Why would you want to stick with the AFM lifters and cam is my question?
Im only keeping the truck about another year so didn't want to pay the extra labor for cam swap.
So if I am reading this correct.  You had all the lifters replaced but still the stock VLOM.  You drove it home, then turned off AFM, the next day it dropped a lifter.
To me, two possibilities.  One, the new lifter failed, which has happened the last year with the lifter issues GM has.  Second, it is possible even with AFM disabled, that a solenoid could have done its job when it wasn't supposed to, especially seeing you had the original VLOM.
I would say that as long as they replaced the new bad lifter and installed a new VLOM, that turning it off again shouldn't give you an issue, unless for some reason another new lifter took a dive.
I don't think you turning it off had anything to do with it.
Edited by newdude
In a previous post, you’d mentioned the truck is driven only about 5 miles each way to work. That tells me it isn’t a VLOM issue but a cold oil sludge issue. Never getting the oil to operating temperature is horrible abuse of the engine for many reasons. Lifter issues are probable for any engine living that life, not just one with AFM. The truck needs to be driven 50+ miles at a clip once a week.
  • Thanks 1
I believe on the reasons my truck has been so trouble free is exactly this. I don't turn the key for under 50 miles and change the oil every 5K. IF I had the situation where I was 5 miles away I'd not only take it for a weekly 100 miler but change oil every 2500 miles or more. Dad had a trip like this when I was a child that was but 8 miles to work. Changed oil every thousand miles and we took weekend trips to anywhere.... very trouble free motors.
How often did you change the oil and filter?
When it fails again you're in the hole for yet another repair.
I have a 2 year warranty from the shop for the lifters so I am not worried.  I will likely have a new truck in the next few months.
I changed when the oil life monitor got to around 30%.  Since I have such a short commute I will change it every 3 months now.
If you are selling the truck it is better to have the AFM lifters in anyways since sometimes it can bring the value down
Interesting. In all my tribulations and posts on here about stuck lifters nobody mentioned the VLOM. I listed what was being done, and nobody said, "Did he change the VLOM?"
I just got off the phone with the mechanic who is working on my truck, and he just learned about the VLOM himself. The GM repair procedure he was going by didn't mention the VLOM but when it failed in <500 miles, he did a little more digging and found out about the VLOM.
Unfortunately there are no VLOMs to be had right now.
That's also why there are no pictures. It's been tore apart in his shop since July 5th. Glad I have other vehicles to drive.
  • 2 months later...
Hey, Had the exact same problem. 2015 Denali 5.3L. Lifters in cylinder 7 failed, mechanic did not replace VLOM and lifters failed again very soon. Lifters and VLOM replaced and seems fine. Figured that the VLOM solenoid for cylinder 7 was leaking allowing oil pressure to the lifters. This causing the pins to be pushed in far enough to let the pushrod collapse when the camshaft is pushing on them in V8 mode. which makes sense as I noticed both times they failed was when the oil pump was on high pressure mode (+3500RPM). My mechanic is thinking the VLOM possibly failed as the pressure relief valve in the pump seems failed as my oil pressure climbs above 550KPA when under high engine RPMS. I can not seem to find any info on high oil pressure.
So even with the 4 cyclinder mode deactivated there is still the possibility oil can get to the lifters causing them to fail.
i would recommend NOT going WOT from off idle or cruise condition while the V4 mode is active or while in Drive grear.   high engine loading and switching from v4 to v8, pressure fluctuations in the oil circuit of the lifters may cause damage.
shift to 5th gear to disable v4 mode , then you can drive like a nut without damaging the lifters
  • 3 months later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
