I bought new tires yesterday and they had to replace two TPMS sensors.  When I got the truck back, I noticed that they were all different pressures.  No big deal.  When I got home, I grabbed my pencil gauge and aired them all up to 45 PSI, but the dash is still showing different pressures.  The two OEM sensors are accurate, but the two replacements are several PSI off.  Is it possible to calibrate the PSI on the system to a known good number?
No, not exactly.
All you can do it set the pressure with a mechanical gauge and then you can re-learn the sensors to the truck. They should be pretty close to what the mechanical gauge is set to.
The TPMS tool is like $12 on amazon, they work good. Then just follow the TPMS procedure to reset them.
If that doesn't work and the aftermarket sensors are still off, then they are to blame and the only way to fix it would be to replace them with different sensors.
The shop that replaced my tires has four OEM take-off sensors and said they'd swap them for me for $20.  I figure that's an easy solution and not a bad price to pay to demount and remount two tires.
Edited by belchfire
Aftermarket sensors tend to be hit or miss.  You can try using the tool to reset them but if they are still off you can't calibrate them to make them more accurate.  I'd go with the OEM option as it will probably give you the most accurate reading since you have the option available.
Not sure if you asked, are the sensors the correct frequency for your truck?
All depends on how old the batteries are...
If they weren't correct frequency they wouldn't connect at all & have no readigs
It's Tim is correct.  Although the oem sensors may work, you won't do yourself any favors by using old sensors.  The batteries in TPMS are not replaceable and once they go, you have to replace the entire sensor.  I haven't seen a guage that  tells  how much life is left in the batteries.
A pencil gauge is far from accurate.  Verify with a a quality dial gauge; cheap gauges like HF gauges can be off by up to 5 psi, and pencial gauges by 10 psi or more; theyr'e entirely dependent upon application speed.
I don't use the dash readout for tire pressure; in fact, I've removed it from the queue to avoid having wasted, useless displays in the cycle.
Edited by 16LT4
I realize that all gauges can be off.  However, given that I used the same gauge on all four tires, I can tell that the replacement sensors are not reading the same as the two OEM sensors.  I scored a set of four OEM sensors from another set of tires/rims that I had, so I am tempted to have those two swapped for the OEMs that I have, but given @It's Tim and @The Zip's comments about battery life, I wonder if that would be smart.  I don't know how old the batteries are in the extras I have.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
