22GMC 3500 Denali Ultimate
I want to swap console for black leather jump seat.
Dealer says 2-3k parts plus $1500 labor.
Can I order a used jump seat with rear vents or do I need other items. Seat belt attached to seat?
Is it easy to swap over? A few seat/floor bolts, attach vents and it is in?
the seat belt for the jump seat is built into the seat, so you're good there.  I believe you take the seats out and the jump seat base uses the same mounting points as the seat bases.  You'd obviously have vent hookups already from having the center console, but I'm unsure of what connections would be different between the console vents vs jump seat vents.  Sorry I couldn't be of much help, but I don't think it would be too bad of a swap for you; it's going the reverse direction that people have more trouble with locating all the parts to swap to full console.  Once you pull console out I believe you'll need a different lower dash trim piece as well.  Look through the modification section in the 2019-2023 half ton threads.  I know there are some posts in there about making the swap that could help you some.
I am looking to do the same thing; looking to pick up a jump seat ideally in black leather…with vents. Putting it in a 2023 AT4 2500. I found this video of a swap a guy did found it pretty helpful.
awesome, that was a great video.  Good to know the front seats don't have to come out to install the jump seat like on prior gen trucks.  I've been looking into the swaps both ways just to get an idea of what wiring was involved as I'm trying to add power to the rear of my jump seat for usb/12v plug since my Custom model doesn't have anything back there from factory.
  • 11 months later...
I have all the parts you need to convert from CC to Jump seat. No miles jumpseat black leather from a 2024 Sierra 2500. Get in touch if you are still looking. Tom
I sat on that thing today while doing my auto-dim mirror mod. I think a concrete block would have been softer. Lord help who has to sit on that or the equally stiff one in the rear.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
