I have a couple springtime fishing trips where I just don't want to fool with a tent. Is there any configuration where I can sleep inside the truck? I'm too tall to sleep on the rear bench seat or the floor. Hoping there is some creative way to help stretch out.
Have you slept in the bed? I'm 5'10, didn't need to bend legs while sleeping diagonally. I had the short bed RST Z71. I could not do that on the Ford F-150 so I had to order the long 6.5' bed so I could sleep comfortably. The Silverado's bed was a lot wider so the 5.10' bed was a lot bigger diagonally than the 5.5' Ford bed. My current Ford F-150 has the tri-fold tonneau cover which I use as shelter. My 2016 Ford had the camper shell, it got way worse gas mileage (I lost around 3 mpg) so I didn't do that for my 2022 Ford F-150 and the 2019 Cheyenne RST Z71.
Edited by Wiggums
I find the front seat more comfortable than the back seat.
Get a tent for your bed. I had one on my truck on a two week camping trip in the desert and it was well worth being able to spread out in the bed. With a tonneau cover I just took the poles out and loose threw the tent in the bed and closed the tonneau. The tent it self opened up over the folded tonneau and provided a little shelf in the bed when the tent was pitched
Edited by jaxcam02
  • Thanks 1
There are several Hotshot tow guys on youtube who show their sleeping setup in the HD2500 trucks (same cab). Even how to run AC and heat so not to idle truck. Some good ideas on there. It can be done.
53 minutes ago, wahoowad said:
What is hotshotting?
Hauling time sensitive loads from one place to another.  Could be a couple hundred miles away or cross country.  Usually loads that aren't large enough to justify a semi to carry it
https://www.truckdriverssalary.com/hot-shot-trucking-101/#:~:text=Hot shots%2C in their true form%2C are medium-duty,using their rigs to haul freight like this.
Edited by dsr611
The bed tents are nice, but burdensome if you wanted to drive your truck around while camping.  The air mattress for the rear seat would seem to be the most logical solution, but man it can get HOT inside the truck during summer months.
I've got an inflatable queen mattress I use in the bed of my TrailBoss. Nothing beats sleeping out under the stars on spring and fall nights! I have a Roll 'n Lock bed cover and I'm 6' and fit well with my tailgate down. If it rains, I can roll the tonneau cover although that worked better back when I used to use a sleeping pad instead of the inflatable mattress.
I saw a setup where a guy made a board that went from the dash to the rear window on the pass side and slept on a pad on top of that.  Didn’t get the details or measurements, sorry, but that’s the idea.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
